Tom Downie
Creamtea
We had a problem with the control panel which affected the ambient lighting. Mentioned it at the 12 month service and they reset the control panel. When asked how do you do that the mechanic replied "disconnect the leisure battery wait the obligatory 10sec and reconnect it". The leisure battery is the one under the bonnet, the one under the rear seat is the car battery. Being that way round is counter intuitive but I was assured that was the case. I would think that was easier than taking the control panel out. Hope that helps.Hi, this forum has already been very helpful - hoping someone may already know this…
The battery gauge on our Grand California (the one on the panel stuck outside the bathroom) is constantly stuck at 100%, permanently showing 0 amp draw regardless of actual draw and 0hrs and minutes remaining, and constantly showing a “charging” status if on hook up (ie it still shows “charging” even having been on hook up for >2 days).
The battery must be charging and holding a charge to some extent, as we can “off grid” for a night and still have some power the following morning (albeit with an apparent drop of voltage eg the water pump seems less strong), but this means we never have any idea how much charge is actually in the battery or what kind of condition it’s in.
Does anyone know how to reset this or what may be the cause or the solution? Turning the red “master” switch off in the electrics locker for >10 mins did not solve, albeit I tried this during the day so possibly solar (which we have as an option) was providing some voltage??
I’m guessing pulling one of the fuses may do it, although I’m reluctant to do anything too “risky” as we’re in the middle of a trip and as it’s working-ish I don’t want to risk making anything worse. I suspect the battery may not be in great condition (we purchased second hand, and the gauge has been reading like this since we got it) but it would be more than useful to at least know what the charge status is. I don’t have a multimeter to hand to directly check but am going to try to pick one up while on this trip (quite remote at the moment).
(note, I have already searched and read in full every battery related post for the GC600 & GC680 on this forum, and didn’t find anything related to this).
