Safeguard made no extra charge when I fitted Air Suspension.The Eibach VW coil overs are height adjustable 20mm-70mm so you can set up the stance of the Cali to your liking. They are a VW supplied item (can source elsewhere for less however) and I should have thought will therefore not impact warranty. You will need to advise insurance company and we had a small addition to pay Safeguard for our changes.
VW0993 or VW0995Does anyone know the part number for the official VW Eibach 30mm lowering springs for the T6?
VW0993 or VW0995
Ok, try vanstyle as they stock themThank you, though I should have been clearer, I’m actually after the Eibach part number so I could check for prices outside of VW
VW will have a markup on the Eibach which will account for the higher cost.
Depending on the mileage of your Cali it would be worth going the extra step of having a damper upgrade to match the springs.
One example of what's available, lots of other sources.
Car Suspension Upgrades | Springs & Coilovers | RTECSHOP
Shop lowering springs, coilovers, suspension kits, anti-roll bars, air suspension and wheel spacers from leading performance brands.www.rtecshop.co.uk
These are the VW ones they use, there isn’t VW markings on them!Under 40,000 miles so hopefully will just do springs.
Assume I can get these https://www.rtecshop.co.uk/eibach-p...gen-transporter-t6-box-sga-/prod_1503297.html
And they will be similar to the ones marked VW?
Yes they are exactly the same, VW supplied ones do not have VW markings on them all markings are Eibach.That’s what I meant. Are these the exact same ones as the VW ones just without the VW markings?
