Calibang
- Messages
- 20
Hi All
Bit of a noob question regarding the batteries on my 2019 Ocean.
The issue is linked with the fridge. Once the battery is fully charged the fridge only stays on for a short while before switching off. If the engine is running, it stays on.
Checking on Control unit display the battery status is showing 80-90% but only 11.0V. When fully charged its shows 100% and 12.5V. This is the bit I am confused about. If the batteries are 8-90% charged, why would it only put out 11.0V (which is probably the reason why the fridge switches off). The lights etc all still work fine.
Does this means the battery needs replacing? If the batteries need replacing, is there somewhere better than main dealer or can they be replaced under warranty? The camper was relatively little used and neglected to charge up the leisure batteries especially during winter.
All help would be greatly appreciated.
