Dealer fit lowering springs
Lexlogie
Lexlogie
North Yorkshire
T6.1 Ocean 150
Have pulled the plug on new ocean 150. Looking at lowering for handling. Are the vw 30mm dealer fit springs good or should you look at alternative? (Have read the dealer ones are not up to it?)
I had dealer fit ones although expensive they do the job and keep warrantee, i did consider coil overs but ride can be harsher, happy with the look and feel of 30mm drop
Had dealer fit springs done at Liverpool, look and ride was fine and kept warranty.
Worth every penny also when for the HD ARB’s at the same time, not sure but you may have the HD ARB’s already on your 6.1
Yes to all of the above. Well worth it for looks and performance!
Also interested in this for a 6.1 Beach, any pictures of the reduced arch gap? It's a difficult choice without having the van but less hassle to get fitted before collection!
Sent from my EML-L09 using Tapatalk
I posted before and after pictures, here in another thread:
I had the dealer fit 30mm sportline springs to my T6 and didn't like the ride, changed for coilovers and find the ride much better, rides the speeds bumps much better too, less crashy.
VW Dealer fit drop 30mm, post delivery to dealer, pre delivery to me! Seems to handle well, good ride, nothing really to compare with though. 18” wheels and the drop seem to fill the arch voids more aesthetically.
There have been some issues with the VW fitted Eibach 30mm lowering springs in that it seems that at least in some vehicles it results in the back of the van appear to 'sag' !! Eibach and VW have subseqeuntly obtained TUV approval for just fitting the lowering springs to the front axle and leaving the original springs on the back axle which keeps the van more 'level'. Your VW dealer should be aware of this, if not ask them to contact VW Technical who most certainly are. It does seem however that some people who have the lowering springs fitted both front and back have been happy with them !?
How do you rate the sports pack?
I‘m pleased with pack. The side sill covers don’t allow for the fitting of side bars of which i would have gone for if i did not have the pack. I feel it is It is a sportier look than the standard van.
Thanks. Looks great, especially the wheels. Do you think that underguard serves a purpose? Hard to see it in your photos against Indium.
Are you aware of the glass upgrade (laminated in the cab, darker tint in living area?)
Undergaurd gives the impression that the van is a little lower than normal so works well with the dropped suspension and 18” inch wheels. The privacy glass is advertised as part of the sports package for the Ocean, however, i think the privacy glass was standard on the Ocean?
Thanks for posting, same specification as Iv ordered & i hadn’t seen one with the sports styling pack fitted.
I might be wrong but i don't think the standard ocean comes with this privacy glass.
