stephen watson
My roof has developed paint bubbles at the end of the roof channels, I think from water pooling there during lockdown. The van is still under 5 year extended warranty but VW refuse to do anything as it's outside the 3 year paint warranty. I've had the seal replaced and tape applied to the edge of the roof, but this is different as there is not the steel in the rubber seal to cause the galvanic corrosion. I'd be interested to hear if anyone else has the same problem and what they intend to do about it? As it started to appear after 4 years I feel morally VW should be offering some goodwill and fix it, but I don't think they will. I'm assuming as the roof is aluminium the problem is essentially cosmetic - I'd be really interested to hear some expert opinions on this (WG please?).
What would you do:
Pursue VW to fix it (lost cause in my opinion)
Leave it as it is
Peel paint off and recoat with either touch up paint or some type of primer. I'm hopeless with getting touch up paint to look professional, but as I intend to keep the van and it is out of sight my main concern is to minimise further damage at minimal cost.
Any other suggestions please?
What would you do:
Leave it as it is
