Graham
- Messages
- 194
Fridge frustrations; some hive mind assistance from the cogniscenti would be really welcomed please.
The fridge will not start; or if it does, only for moments few. A per many others, the relay fires but fridge doesn't hold on. Earth shunt is good (shunt repair in place), the relay (new) is good and the leisure batteries (new) good (and kept topped up via solar). Symptoms are the same whether on battery or hook-up.
Fridge removed and have proven that (with thanks to Penguin refrigeration fault guides) when directly connected to a good 12v battery and the thermostat bypassed with link wire, the compressor runs continuously and cools the box. So it doesn't appear to be an issue with the cold-making end of things.
The fridge thermistor provides a resistance reading (9.8kohm at about 18c, but no idea if this is in spec).
So now I think one of 2 faults possible: danfoss fridge controller; something on the van-side power or control system.
As I can get the fridge compressor to run, the fridge controller shows no fault code.
On the van side, I have proven a good 13.6v to the fridge supply. With the van control unit on, I can see a 4.8v control signal across the white/brown & green/brown (thermistor) pair - is this expected? This sinks to 0v when van control unit is off.
On the fridge side, I can see 68ohms between the brown (ground) and yellow so I don't think it is the control board resistor others have written about. But that still doesn't mean the fridge controller is fault free.
So I am a bit baffled. I'm leaning toward the fridge control unit but still not quite convinced.
What thoughts from the hive mind?
