Louis II
Hi all, I have what seems a relatively common issue but struggling to resolve despite lots of searching so this is thread is my last hope before biting the bullet and heading to the garage.
It started with intermittent ABS, Traction Control, Tyre Pressure & Stop Start errors that became permanent
Bought a carista which pointed to rear right ABS Sensor so replaced the sensor after which the problem went away for a week or so then returned
After quite a bit of searching on here and on the T5 Forum I located and inspected connectors behind the rear light cluster for corrosion but they were immaculate.
Also tested voltage at the sensor which reads 11.1v which is 1v lower than I get across the battery terminals. I get the same reading at the connectors behind the rear light cluster so assume the wiring between there & the sensor is OK.
Last time the error came up it was accompanied by something like "low voltage terminal 30", can't remember the exact code but has now gone. As a result I removed, checked & refitted all the fuses in the box next to the battery, all spotless connections & no sign of any damage.
Finally yesterday I did a long drive on the motorway and after about 45 mins driving the faults went away, they then returned when I started up a few hours later to set off home but again cleared after 45mins driving on the motorway.
Does anyone know if this could be caused by the battery reaching end of life? It's the original 6yrs old and about 60k miles used as daily drive mostly for a 15 mile commute in traffic.
Any other suggestions before I bite the bullet and head to the garage would be much appreciated
