jimmywease
Has anyone successfully run a Cadac from a cheapo CP250 canister?
For shorter trips, I am trying to facilitate leaving my 907 cylinder at home, in favour of canisters.
Until now, I was using a Campingaz Camping Chef, plus a Cadac Safari Chef 2 LP. They were connected to the 907, via a quick-release splitter, thus allowing one or both appliances to be connected.
To replace the Camping Chef, I bought a Bistro2 type single stove and CP250 canisters. To run the Cadac from canisters, I purchased the Cadac regulator:
cadacuk.com
All well and good, except this means I need two types of canisters on board: the cheapo CP250 for the Bistro and the C500 for the Cadac.
Luckily amazon is awash with cheap adaptors, to convert a CP250 for use with C500 type fittings:
Sadly, the recess in the amazon adaptor is 22mm dia while the Cadac regulator seems to be 23mm dia, so they won’t connect.
Anyone found an adaptor out there, that fits?
Cadac Threaded Cartridge Regulator QR | Cadac UK
Negating the need to have a bulky gas cylinder, the Threaded Cartridge Regulator with QR connection is the perfect lightweight alternative for picnics, camping and trips to the beach. Enabling low pressure appliances to operate off EN417 gas cartridges, just simply screw onto the cartridge...
