Tanks, Will phone MondayThanks for the great feedback folks, with regards the emails I've not seen them tbh (perhaps they've been spammed?), we're making a sent of infills up for a chap this week but just as a catch all can you drop the office a call please and they'll capture your details. 01246 912712. Cheers![]()
We have made a lot of use of our Comfortz awning room over the 4 years we have had it in various ways. We tried putting two of them together to make a bigger dining area.
This worked very well except when it rained as the rain would come through the join between the awnings.
@Borris designed some panels to join the awnings with Velcro on the join. This provided a wind and watertight join and made it a very comfortable space.
Comfortz made the join in the same material so it matched in very well. The roof join was made with a gutter like join to run the water away. We had a lot of meals in this awning configuration which worked well.
It is important to secure the awning very well and tie down kits are available from the shop.
This is one of the strongest ones but you can also get 2 shorter ones that fit into the Kador strip.
We used 2 sets of tie down straps at Highlands End on the recent very windy Club Meet. You can see them both in this picture, as well as get some idea about the strength of the wind from the hedge in the background.
You mentioned the gap between the wall at each end and the roof. If you get a pair of plastic clips like these, they grip the awning firmly and can be pulled with a bungee cord and fixed to a peg so that the gap is closed.
I don't have a picture of them in place at present, but I'll try to take one next time we use them.
The sum up I think this awning room is very useful. It folds into a very small bag which can be easily carried, in with the folding seats, for example. It is quick and easy to put up. It will act as a place to put the items you don't need in the Cali when you are on site and need the space inside for sleeping. It is also very good value.
They seem to be called Ground Sheet clips or Tarpaulin Clips here is a link to an Amazon selectionBeing able to close the gap between roof and side panels would be a big plus....ours has been great but I’m always conscious of draught and/or rain coming in. The gap is quite big on a windy day.
I’d be very keen to know more about these clips and how it looks!
If you look at post #20 at the end of the first page of this thread there are pictures of the panels there as made for the black awning room that Comfortz make. I would think as they are not a regular item the cost would probably need to be agreed with the shop.Has anyone got a picture of the fill-in panels please? How much did they cost?
£35/40 from memory, haven’t used them yet and you will still need limpetsif you don’t want your paint damagedHas anyone got a picture of the fill-in panels please? How much did they cost?
We have the Comfortz Awning Room from the Club Shop and it fits our T6.1Hi. Does anybody know if the latest version works with T6.1? It only says t5 and t6. Thanks
Thank you. I’ll get it ordered today.We have the Comfortz Awning Room from the Club Shop and it fits our T6.1
On first use we found we needed to buy the Infills to close the gap between the awning room and van.
I made side connectors for about £40 using the following.What would be the best way to attach the side fill-in to the van? I've seen limpets and magnets mentioned.
Me too please.Thanks. Interested to see some pics
Here you go Rams66, Marks, Shuftie any anyone interested in the DIY attachment for the Comfortz side panel to the van.Can I add to the me too's too?![]()
FurtherHere you go Rams66, Marks, Shuftie any anyone interested in the DIY attachment for the Comfortz side panel to the van.
Firstly, I would say that the optional bespoke extension panels made by Comfortz would be an added benefit to use with this fixing method.
Even better if these were fitted at the van contact side with the Keder tape I mentioned in my post.
All the additional kit apart from the figure of 8 joining pieces will fold and fit in the Comfortz bag (inc the Fiamma skirt)
Mine lives on the back shelf
View attachment 77432View attachment 77433
So to the fitting
Firstly the Fiamma skirt. Note the blue bungee to the rear wheel. The Fiamma hook would destroy the Davenport alloy if hooked on to it.
I also added a Velcro pad to each section to allow the rear wheel cover to lie flush with the skirt to prevent the power door catching it.
starting at the rear, the black keder tape with Velcro add (I stapled mine as well as the glue, the ideal would be to have it stitched in but I don’t have a machine) is fitted to the room Velcro.
Then a 2 metre section of the kampa magnetic awning adapter is placed on the van side. NB magnets are much stronger on one face than other due to padding.
The two are then joined with 2 sections of Keder figure of 8 connector
View attachment 77436View attachment 77437View attachment 77438
The next shot shows the join from inside the room
The front side panel fitting is similar apart from being reluctant to buy a second adapter I stuck a piece of Velcro on the inner face of the lower section of the drivers door and split the Keder tape below the Keder 1 metre figure of 8 connector to allow the lower edge of the Keder tape to be attached to the door.
With a second Kampa adapter you could omit this and run it full length on the drivers door.
Due to attachment restricts will have to post
Further the mages in a new post
Wow seems more effort than a lot of blow-up drive-away awnings by the time you add and fit all the bits !
I would agree but depends on the amount of use one will have for an awning.Wow seems more effort than a lot of blow-up drive-away awnings by the time you add and fit all the bits !
Yes. It seems that way. We have a G3 residence:
A lot of faff to put up, but does have fringe benefits over our Hexaway, including the possibility of being heated by the parking heater.
