Minimum.I found some more scrapes in the enamel coating.
I think that I’m now looking at about 50% refund of the £1039 purchase price for me to accept it as it is.
I put the penny there to send the manufacturer the photos and so they could gauge the size of the scrapes.I wouldn’t accept it at all with that damage.
I find it odd that they’ve helped highlight the damaged areas with coins though.
Absolutely. The bolts and brackets need replacing and ~£500 off.Did you say some of the brackets / bolts were missing? they charge a fortune for replacements.
I'd want the missing bits replaced along with the 50% off
It was in a plastic bag, and the plastic bag with polystyrene brackets. It was then in a long cardboard box with tough reinforced cardboard edgings, and thick chipboard wood rectangles.It really was under a pallet of bricks!
Was the plastic wrapping damaged or was it wrapped after the scrapes?
519 quid isn't chicken feed though, you mightI think that half price would be fair (£519 reduction)
have a cock fight on your hands there.
Philip? Sh1t ...Indeed.
They want to send the brackets and replacement end caps. That’s it! I know it’s not their fault, but not even an apology or acknowledgement of the inconvenience.
=====Quote=====
Good Afternoon
Thank you for forwarding the photographs most useful for us. In reply I can advise i have re-raised the order to send you the missing brackets and I am hoping to get those shipped today, I can send you a pair of replacement end caps if you would be happy to fit them your self and the same for the end caps for the front bar. I would send a replacement buy [but] that was the last stock item available and new stock as now been delayed to the 31st May, Let me know if you want the end caps sent.
I await your advice.
Kind Regards,
Philip
=====/Quote=====
Indeed.
=====Quote=====
Good Afternoon
Kind Regards,
Philip
=====/Quote=====
Moving towards a satisfactory result then. What they are proposing and a little compensation should do it ?
Have you got someone putting it up for you? If thats a fully cantilevered one ie like the cali awning but no legs, the fixings should be substantial.
We've just done at work about that length outside a restored park pavilion & had to put steel spreaders inside the wall. Engineer thought that with a bit of wind load etc it could pull the the outer skin of brickwork down if it was just rawlbolted into that.
Are you going to fit this one with an electric motor?![]()
Brackets bolted in place.
Awning wound in.
Awning extended.
Random photo of two racially harmonious chickens.
