Fuse gone ? Heating not possible
Toot-toot
Toot-toot
New Forest
T5 SE 140
Just went to switch on the heating and a message on the control panel says “heating not possible “ does anyone know what that message means we must check ??
Switch Off Control Panel using L lower button. Wait 1 minute. Switch On using L lower button and try heater.
Or - try this.
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Hi toot - toot
check:
fuel ? how much fuel is in your tank ?
Battery charge? Try with engine running
Setting, is the heater set on High ? Try turning it down to level three and try again.
search the forum, @WelshGas has posted a reset procedure and fault codes
edit: WG kindly posted whist I was typing :thumb
Thank you we are now up and running!!! The on / off did the trick..... slight panic when nothing worked as we have just forked out for three new batteries ( supplied and fitted by Vw)
Thank you again
This just saved us from a very chilly night!
Thank you!
P
Christopher Thomas
Christopher Thomas
P
nigpdreadingfc
nigpdreadingfc
Soton Campers
8K
GrumpyGranddad
G
