What are these ?
Scoobz1
Peaks
Just been sorting out the California now that we might be able to use it and came across these ?
Can anybody tell me what they are and what they are used for please.
Also came across 4 metal pegs in a polythene bag similar to what the winder came in for the wind-out awning so assume it is for this even though there isn't any associated straps
I think the strap is to support the table from the headrest, the other piece is one part of a cup holder that fits into the kitchen rail.
If you put “what are these for” in the search bar you will find answers to this regularly asked question :thumb
Brilliant just did - tried more specific terms initially
Pegs for the Awning leg ground plate? They each have 2 holes, so 4 pegs.
table strap. half of a drinks holder. and some pegs
Cheers for that will have to track down the other bit now (-:
Then ideally you need to get hold of the special insert that makes it into a proper cup holder - normal cups & cans just fall through the hole otherwise.
Its the bit on the right below that doesn't come with the T6.1 . Best be sitting down if you enquire about the price from VW.
Go on entertain us then - how much ? Seen a mod where the poster used a bit of heavy fabric strapping (similar to what you get on the handle of hold-alls)
About £25 a time just for the insert. Need to search for Amarok parts to find them.
Chocolate tea pot comes to mind,
what were VW thinking, let’s give Amarok owners a cup holder to use, let’s give California owners a mini basket ball ring !
Big Tedz does a cheaper insert
