Lambeth Cali
Check Control Panel Diagnostics.Help!
The generator symbol keeps flashing with G and then back to plug symbol. It keeps chiming and flashing roof open. It’s not.
I think I have a flat leisure battery. I’ve parked up on drive and put on charge. I’ve owned it 12 yrs and it’s never made a single sound. But this is a new unit.
What voltage is the Control Panel showing for the Leisure Batteries?I’ve just read the thread on this.
I don’t want to go anywhere near a dealer. I don’t think they have a clue about Calis apart from the engine. Roof working fine at the moment. Time will tell.![]()
Roof fault error message
Hi Thanks for the guidance. I get as far as step 5 and then it says error 1000 at the top. Underneath it says ERASE PRESS ESC 5S. Which is the escape button? Is 5S five times? Cheers Escape Button - Bottom R, and 5S is 5 seconds.vwcaliforniaclub.com
I’ll give it its annual proper clean tomorrow and clear all the leaves away.
I’ll look tomorrow. What should it be?What voltage is the Control Panel showing for the Leisure Batteries?
It looks like you have a timer set? I think that could be so that the heaterView attachment 75128
I think we’re back to normal now. Error cleared and roof raised and lowered and now showing as down.
I think the flat leisure battery got it confused. Does anyone know if that’s what Error 1000 means?
Based on another thread, the 1000 is an estimate of how much you've saved yourself by asking here rather than going to a VWC 'California Specialist' who would have replaced the panel for £800 plus vat.Does anyone know if that’s what Error 1000 means?
Oh it’s worse than that. THIS IS THE NEW PANEL!Based on another thread, the 1000 is an estimate of how much you've saved yourself by asking here rather than going to a VWC 'California Specialist' who would have replaced the panel for £800 plus vat.
That would explain the flat battery if the heater was set to come on every day!It looks like you have a timer set? I think that could be so that the heater
starts up at a certain time, or its an alarm set.
The No1 in the clock symbol.
You’ll have to change the Control Panel screen to show Battery voltage. Select Display and select Battery.
12.9 is OK.View attachment 75177
Plugged in 13.4v 0.2 A. Unplugged 12.9v 0.0A. Is that good? 13 year old battery, only really used to power fridge tbh.View attachment 75178
Thanks that’s very helpful.12.9 is OK.
Now leave Off charge for a week. It should be 12.6 or more if the 2 Leisure Batteries are holding their charge with nothing switched on or anything plugged into 12v sockets.
Just a thought: mine is 12 years old too. Last year I got the leisure batteries replaced with new ones, and the other day I also replaced the engine battery for the for the first time. Everything works really well now. Maybe you've done this already, in which case I can't help.Help!
The engine battery died last year and was replaced by the AA.Just a thought: mine is 12 years old too. Last year I got the leisure batteries replaced with new ones, and the other day I also replaced the engine battery for the for the first time. Everything works really well now. Maybe you've done this already, in which case I can't help.
I regularly have mine on hook up charge, it hasn't been on chargeThe engine battery died last year and was replaced by the AA.
I’m waiting until Tuesday to see how much charge the leisure batteries hold.
Who's dirty fingers have been turning on your control panel ?I regularly have mine on hook up charge, it hasn't been on charge
for a week and i did a 20 minute drive this morning.
Just had a look at what the battery level is and its looking
good. 15 yrs this June, original batteries.
Thats on your screen, give it a wipe.Who's dirty fingers have been turning on your control panel ?
On my screen as well.Thats on your screen, give it a wipe.
You replaced the control panel though, yes? Old one had black text?I regularly have mine on hook up charge, it hasn't been on charge
So after 6 days it showing 12.5v and 90%. That’s ok isn’t it? What do you think?12.9 is OK.
I think when camping unplugged with the fridge on I reckon we loose 10% a day. We often camped a whole week without needing to plug in. I would then plug in at the next site.
Of course the roof is showing up, which it isn’t. I’m starting to ignore the sensors. I can hear the roof locking when it shuts. I never take my finger off the button until the noise stops. I suppose some would think that was a risky thing to ignore.
