westfalia
You haven't got a workshop and a load of time on your hands have you?Just being reading some posts from the past a guy removed his pump and fitted a new one ,very interesting again uneven lifting issue.looking at the pump it has a number of Allen bolt plugs these are quite often check valves which lock the ports off when the pump stops ie stopping the fluid draining back to the tank locking the fluid into the cylinder ,or they allow the roof cylinders to lift through pilot lines when the pump starts.
the guys issue might have been that debris has become trapped between the check valve so when the pump stops the fluid slowly passes over the check valve which then causes the cylinder to drop.each cylinder will have its own check valve so again if debris was trapped it could also cause a cylinder to drop or lift slow due to the check not lifting enough which would restricts the fluid flow.
the check valves can be removed and cleaned but the debris has come from somewhere probably cylinder seals or the seals on the cartridge check valves.
This probably why the dealer changes the pump, but can’t see why this would be the issue with a new van.
There is an opening for someone fluent with the Cali roof. One member was
charged about 3.5k for VW to replace stuff.
