Joker 1299
I did think you would have plastered the walls.Ha. Poor kurienp. They sell cable clips in b and m . Stock up on cable clips. Wood screws and beer all in one shop.
I think he is more interested in getting plastered.I did think you would have plastered the walls.![]()
Not sure what you are saying about my fellow Yorkshire man...I think he is more interested in getting plastered.
Here you go sub three. And dodge, theres no benefit really over the 3 pin converter. I had it laying around spare so fitted it whilst wiring up the garage. Keeps the other sockets free for my beer fridge a d Hoover.
Are they a straight swap connector/coding wise? Also how much to purchase? Thanks.I didn't buy them today, but took advantage of the good weather and fitted the H7 headlights, recoded to keep the dips on when the main beam is on. Much easier than I feared, even though neither of the videos I watched had front parking sensors so I nearly pulled that wire off! Amazing how easy it is to pull the front off once you pluck up the courage to give it a good tug!
View attachment 74363View attachment 74364
Simple swap yes, if you want the dips to stay on when high beam is on (which you will do) you need to recode for that, did that with the beta Carista. Picked them up on eBay with 130% bulbs, LED DRLs and sidelights for £190.Are they a straight swap connector/coding wise? Also how much to purchase? Thanks.
na na! we are in the 21st century. Looking to make everything wirelessHa. Poor kurienp. They sell cable clips in b and m . Stock up on cable clips. Wood screws and beer all in one shop.
Yes, it fouls slightly.Hi @GrumpyGranddad do you have to lift the carpet out the way to pull out the underbench drawer. Many thanks
Understand.Thanks @GrumpyGranddad, think we'll go without as thats the case.
ooh do they just fit within the wheel wells ? no drilling required for the rear? if so where did you get them from please.Mud Flaps
I have these on mine very easy to fit 15 mins . Went for these stubbies as my van is lowered 30mm and the factory flaps were attached to the rear bumper which if bottomed out would be an expensive repair £160 v £33 from customveedubs eBayooh do they just fit within the wheel wells ? no drilling required for the rear? if so where did you get them from please.
| Ridgemonkey GorillaBox Combi Case | 1 | £12.99 |
| Brandrup Air-Safe for use with VW T5/T6/T6.1 & Caddy - Vehicles WITHOUT Automatic Closing Aid 100 150 052 | 1 | £17.99 |
| Brandrup Anti-slip Cupboard Inlays VW T6.1/T6/T5 California SE / Ocean - T6.1/T6/T5 set of 6 - 100 704 510 | 1 | £46.99 |
| Brandrup Anti-slip Cupboard Inlays VW T6.1/T6/T5 California SE / Ocean - T6.1/T6/T5 for the right side of the scullery - 100 704 511 | 1 | £14.99 |
| Brandrup Noise Reducing Mat for the Drawer of Bench Seat VW T6/T5 California Ocean/SE - Drawer Floor Carpet Black 100 708 506 | 1 | £29.99 |
| Brandrup Noise Reducing Mat for the Drawer of Bench Seat VW T6/T5 California Ocean/SE - Drawer Sides Carpet Black 100 708 518 Pre-Order product Release date: April 24, 2021 at 13:12 (UTC+0) | 1 | £39.99 |
| Brandrup VW California Pillow "Circuit/Palladium" Pre-Order product Release date: March 30, 2021 at 15:56 (UTC+0) | 2 | £95.98 |
| Brandrup Velour carpet for passenger compartment, VW T6/T5 California Ocean/SE "Palladium" - Two Rails 100 708 610 | 1 | £164.99 |
| Brandrup ISO-TOP MK VI for VW T6 T6.1 California with electrohydraulic Front Opening Roof | 1 | £549.99 |
| Brandrup Flyout for ISO-TOP MK VI | 1 | £55.99 |
Here you go Zippster - https://travelinlite-transporters.c...6-mud-flaps-15-18-perfect-fit-easy-to-installooh do they just fit within the wheel wells ? no drilling required for the rear? if so where did you get them from please.
Are you sure you’ve got the correct air safe ? I thought all oceans had the closing assistance.I went a little bit crazy with this weeks order. I took a picture of my "van shelf" in the garage on Friday and its getting quite scary, think i should maybe order a second van for my overspill of accessories.
This little lot is out for delivery tomorrow.
Ridgemonkey GorillaBox Combi Case 1 £12.99 Brandrup Air-Safe for use with VW T5/T6/T6.1 & Caddy - Vehicles WITHOUT Automatic Closing Aid 100 150 052 1 £17.99 Brandrup Anti-slip Cupboard Inlays VW T6.1/T6/T5 California SE / Ocean - T6.1/T6/T5 set of 6 - 100 704 510 1 £46.99 Brandrup Anti-slip Cupboard Inlays VW T6.1/T6/T5 California SE / Ocean - T6.1/T6/T5 for the right side of the scullery - 100 704 511 1 £14.99 Brandrup Noise Reducing Mat for the Drawer of Bench Seat VW T6/T5 California Ocean/SE - Drawer Floor Carpet Black 100 708 506 1 £29.99 Brandrup Noise Reducing Mat for the Drawer of Bench Seat VW T6/T5 California Ocean/SE - Drawer Sides Carpet Black 100 708 518
Pre-Order product
Release date:
April 24, 2021 at 13:12 (UTC+0)1 £39.99 Brandrup VW California Pillow "Circuit/Palladium"
Pre-Order product
Release date:
March 30, 2021 at 15:56 (UTC+0)2 £95.98 Brandrup Velour carpet for passenger compartment, VW T6/T5 California Ocean/SE "Palladium" - Two Rails 100 708 610 1 £164.99 Brandrup ISO-TOP MK VI for VW T6 T6.1 California with electrohydraulic Front Opening Roof 1 £549.99 Brandrup Flyout for ISO-TOP MK VI 1 £55.99
Hell of a shopping list.[TD]Brandrup Velour carpet for passenger compartment, VW T6/T5 California Ocean/SE "Palladium" - Two Rails 100 708 610[/TD]
[TD]1[/TD]
[TD]£164.99[/TD]
The T6.1 ends in 614 as the code. Only difference is that the T6.1 version is about 90mm longer on the bit that slides under the rear bench. It’s more important to get the right version for any boot carpets as the light is in a different place and the boot is shorter and for the front footwell carpets as the shape is different.Hell of a shopping list.
This one caught my eye, having just bought similar myself. Not sure why you wouldn’t have got the T6.1 version?
That’s for the heads up guys. I will see if I can exchange it.The T6.1 ends in 614 as the code. Only difference is that the T6.1 version is about 90mm longer on the bit that slides under the rear bench. It’s more important to get the right version for any boot carpets as the light is in a different place and the boot is shorter and for the front footwell carpets as the shape is different.
thanks mate, can you post a piccy when fitted ! cheers
