Tarquers
Having found this section and read most of it, thanks @bvddobb, it seems like a great place to share some thoughts I have for future modifications, as well as look for others experience. To start of with, I am not looking to replace a full on (insert your 4x4 brand here) but rather take a vehcile already well suited to long distance leisure travel and add a few enhancements that will either improve comfort, convenience or safety, without drastically affecting the usability of the Cali.
suspension
probably starting with the most expensive area, I am thinking about VB air suspension. The idea of improved ground clearance does seem attractive but the reality is that an increase in suspension lift with springs is going to do little to improve ground clearance in terms of departure and break over angle. What is more valuable in my opinion is suspension travel and therefore being able to keep wheels on the ground and keep traction. Raised suspension also allows options for more tyre choice in terms of size, which also increase ground clearance so a lift becomes interesting, until I want to get into A car park or under a road toll.
my thinking is that air suspension keeps me standard until I need to go up, or down, but has the advantage of levelling out the van for camping. I know I could carry levelling ramps but, this is a multi part solution. Advantage of VB is that it does not compromise the factory warranty. Downsides are that the more remove I go, the greater the chance of a problem, so it would be good to understand if VB users have had issues. I have had various JLR cars in Middle East all have leaks from the air suspension.
wheels and tyres
quick and relatively cheap in terms of gains per $ are new tyres. I love the look of BFG AT but long experience tells me that these tyres suck power, but also need a lot of grunt to get the most out of them. Having gone for a 150 engine for longevity and “simplicity”, I want to keep things simple. I am also not a fan of oversized tyres as again, this bleeds power quickly. I would therefore be looking at getting a robust AT tyre with the least aggressive tread as a compromise, after all, no matter where I go, trips will generally be 80% or greater on tarmac. My preference would be smallest steel wheels possible, get the biggest tyre sidewall and steel can be hammered back into shape if damaged. I believe it is 17”.
I would also look to have an option to carry a second spare, probably mounted when needed on a modified rear carrier, as well as keeping one underneath the van. The reality is the most accessible spare becomes the first spare, and whilst it takes a chunk of trip payload, anything mountainous having the second spare is probably worth it.
recovery equipment
in my experience winches are great for recovering other people and I have rarely used my winch to recover me. It is also a weight concern for 99% of the time, so I need to think hard and consider the knock on implications.
Having somewhere to be winched on is important too. At the rear I have the factory tow bar which is acceptable in a straight pull backwards without shock ie not in a snatch recovery but a tow. At the front I have seen reinforced recovery eyes made by a German company that are popular in Australia.
I already have a collection of straps, shackles and various other bridles which are compact, easy to store and can live in the van without taking up too much space.
I will look at alternatives to the standard jack, either carry a jacking board which can give stability on loose surfaces or a trolley jack but weight is again a concern. I always carry a cordless rattle gun with correct size socket and I will mount an air compressor, probably an ARB single under the bonnet. One area to research is to see if it’s possible to tap into the VB air compressor.
tyre repair kits are great to carry, even for repairing sidewall punctures in an emergency and take up no space.
safety
minimum legal requirements in most of Europe do cover this, fire extinguisher, safety vests, first aid kit, warning triangle, but I would add safety glasses, work gloves, degreaser/cleaners for hands, and a mat to lay on. Typically a set of gear that is always stowed in the van anyway.
storage and extra luggage
I do get a bit OCD on storing things in the right place, but for me part of the fun is knowing where everything is and not having to rummage or worry about forgetting things. I also don’t want to worry about stuff flying around so aim is to make as much use of existing space. Problem with a van is that by the nature of it, there is not much that isn’t open (in a beach of course). will need to investigaPte what can go into the jack storage compartment, the space under the bonnet and see if there are any other easy to access but out of the way spaces. Maybe do something custom with the storage under the bench. Fridge will be mounted on the floor rails under the pull out cooker. I am considering a rear rack to carry spare wheel as mentioned and could also then include a box for breakdown kit so everything can be accessed outside of the van to prevent unpacking ( in the dark and rain as that’s when things invariably go wrong).
my intention is to come back to this thread with various products and solutions as each one gets locked in place and to attract input from others that have their own tips and tricks as well as those more expert than me in how to modify, remove or otherwise fix panels etc.
suspension
wheels and tyres
recovery equipment
safety
