NRDSRFR
I did a test as recommended by an official dealer and poured a bottle of water down the front drain which is under the elevating roof right near the a pillar. Some of the water drains out by the wheel well on both sides but on the right side some water leaks out of the roller blind.
I thought the drain has a rubber tube or something which guides the water where it needs to be. I don’t know what it looks like on the inside but they inspected it and said I have to go to the body shop and do the whole process of cutting out the top panel and replacing it with a plastic or fibreglass one.
Last year I had a body shop fix some of the paint bubbling on that infamous panel but they didn’t take the whole panel off I don’t think. They also took off the windscreen and resealed it so that shouldn’t be the source.
It looks like I can’t upload a video from my phone so I’ll post that later to show if it helps.
I just need some better information about that little drain hole because water is obviously getting to the wheel well where it should exit but I just can’t get my head around how the panel should have anything to do with it because where the drain hole starts it looks like it should go under the panel
