laeli
Hello everybody, I just got myself a second hand T5 (2007) and I’m puzzled by the Webasto aux heating. I have read all posts about the earth shunt issue, but before claiming I have a problem I would like to better understand what would be considered “normal operation” as I lack a reference. I would appreciate if someone with a good functioning heater could share some voltage values/drain of their equipment when operating for hours.
Mine starts with large battery drain (I understand that this is normal), runs for 6-7h and then turns off. Completely, no light on the symbol in the control unit, neither red nor yellow.
Last weekend I took a picture when it stopped, it showed 12.2V and 40%. Fuel was above half, so plenty of it.
Problem is that with this % it won’t kick off again, when I tried, the battery dropped to 10% (I didn’t take a picture, I think voltage was showing 11.8V) and, after few moments of clicking sounds, the whole system switches off again. I need to start the engine, just 5-10 minutes running, then the battery is showing 100% and I can immediately restart the heater. Note I only keep level 1-2 when it runs as it is warm enough.
Is this its normal way of working? Just 6-7h of hot air, so less than a night sleep? Is it normal that it stops at 12.2V?
Second question: I watched during (seemingly) proper functioning, some time after starting it with engine on, and there’s always a constant consumption of around -4.2A.
Nothing else is on, no fridge, no lights, nothing plugged. Why is that? I thought that after starting it should just run on diesel, not the battery. Is this due to the fan of the webasto? Is -4.2A a normal value? (Then no surprise the battery drops to insufficient level in 6-7h I guess....)
Any tips to get it running longer are appreciated. Anything else I should check? (note both leisure batteries were recently replaced, they’re not as old as the van!)
Thank you very much.
Elisa
Problem is that with this % it won’t kick off again, when I tried, the battery dropped to 10% (I didn’t take a picture, I think voltage was showing 11.8V) and, after few moments of clicking sounds, the whole system switches off again. I need to start the engine, just 5-10 minutes running, then the battery is showing 100% and I can immediately restart the heater. Note I only keep level 1-2 when it runs as it is warm enough.Is this its normal way of working? Just 6-7h of hot air, so less than a night sleep? Is it normal that it stops at 12.2V?
Nothing else is on, no fridge, no lights, nothing plugged. Why is that? I thought that after starting it should just run on diesel, not the battery. Is this due to the fan of the webasto? Is -4.2A a normal value? (Then no surprise the battery drops to insufficient level in 6-7h I guess....)Any tips to get it running longer are appreciated. Anything else I should check? (note both leisure batteries were recently replaced, they’re not as old as the van!)
Elisa
