That's why I connected my Solar Panel below the Cube fuse on the rear Leisure Battery.It would be better if the Bluetooth voltage monitor was fitted on the rear leisure battery on the battery terminal side of the fuse so when charging a higher voltage (~14v) would be shown if all OK (same voltage as shown on Control Panel) OR if the fuse was blown it would only show the lower battery voltage (~12v)
If the Cube fuse fails then the Solar Voltage will not be seen by the Control Panel, so giving an early indication that I'm running on 1 battery only.
