D
Doug Curran
My 2005 German (imported to Canada) T5 California does not light the #16 Exhaust Emissions warning light on startup. I have had the ECU tested and the instrument cluster repaired (sent to England) and there are no fault codes showing. The VW Factory Workshop Manual notes all warning lights that are "Ignition On" activated, but the Exhaust Emissions/Engine Check Light is not noted as one of them. See attached photo. British Columbia inspection requirements indicate the "check Engine Light" must light for 2 seconds as self-check on startup. I am unable to get roadworthy without this function. Does anyone else have a 2005 T5 (2.5 cyl.) where the #16 engine light does not come on at 'Ignition On'? My local VW dealer is unable to find a fault. Am at wits end with what is now a $45,000 ashtray.
