Solar Panels
D
Dave Wickham
Newcastle upon Tyne
Can anyone recommend a decent portable solar panel that plugs directly into the Cali external hook-up socket? Thanks in anticipation of some guidance.
The external socket is for mains hook up (240V). Solar panels need to be connected to the leisure battery. I’m sure someone will correct me if that is wrong.
Edit - link to the Solar Panel section
As @AlisonF has said, Solar panels are 12/24 v external socket is 230 v Mains only.
You could have an external 12 v socket wired to one of the Leisure Batteries.
Thanks, attachment to the front battery under passenger seat will be more practical for access than the one at the rear? Still the front one looks a devil to get out - it has a rubber cover and its damn hard to get it off. Looks like a job for an auto-electrician
Only has to be done once. To wire a socket on. Then plug the panel into the socket.
It is in fact fairly easy to get at.
Ignition Off, and leave keys in pocket. You'll see why shortly.
Undo 4 bolts/nuts holding seat to rails. Once undone lift rear of seat and lean seat forward so backrest leans against dashboard. There are 2 connectors on wiring into seat base. For airbag and seat heating. These Do Not have to be disconnected but if you do Do Not switch on ignition until reconnected.
Pull cover of battery and wire in socket correctly to +tve and - tve terminals.
Refit cover and seat.
Hi Dave, are you set against a permanent panel or two, on the roof? I’m a newbie Cali owner and deliberated for a long time, whilst waiting for my van, about portable v fixed. I finally went for fixed. The advantage for me is that it is ‘fit and forget’ and I had it installed to charge both leisure and starter batteries. I also retain valuable storage space in the van that the portable panel would have taken up. I got a bit hung up on having the curly cable laying across the roof but it’s fine (might put a clear paint protection strip under it at some point, but probably not necessary).
Portable does have the advantage that you can orientate it to suit the position of the sun more easily than by moving the van. In hot locations you might want to park the van in the shade but want solar panel in the sunshine. Don’t forget if you buy a portable panel that you’ll need a charge controller - some portables come with one built in, some don’t.
The other consideration with fixed is height of the van. The panels I had fitted still give a little clearance under 2m height barriers (but i’ve had my van lowered 30mm anyway which gives a little piece of mind).
Had I gone for portable, I had planned to install an Anderson plug at the rear adjacent to the shower outlet and, for flexibility, possibly a second Anderson plug connected to the front leisure battery.
One other point is that it is apparently preferable to connect the negative cable from the solar to the chassis near the battery. I think this is in order that the van’s battery monitoring can ‘see’ the solar charge (others on here can probably provide a better explanation).
Forgot to say that another advantage of a fixed solar panel for me is that I have dashcams fitted that have ‘parking mode’. Parking mode will draw power from the starter battery. Could drain the starter battery if parked for an extended period. I have a ‘power magic pro’ fitted which switches the dashcams off when the battery charge level reaches a certain threshold. That’s good in one obvious respect but of course there’s then no dashcam monitoring of the parked vehicle. The solar setup extends the period of time the dashcams will stay active (obviously subject to amount of sunshine).
Very helpful thanks. Does charging the starter battery (as well as the leisure) allow you to use the stereo constantly when parked up if the panels are charging?
unfortunately no. The time off for the stereo is programmed into the BCM. You will still need to switch it on again after 20 minutes
I’m no expert but somehow doubt it. The charge controller prioritised the leisure batteries and when they are ‘full’ then trickle charges the starter battery. Lot’s of variables at play.
I went for a foldable 120W from OFFgridtec and the Victron MPPT 75/15 controller. It can also fit inside the windshield, I connect it to the front leisure battery.
Of course i can also charge the Engine battery by plugging into the dash cigarette socket near the gear lever or charge both Leisure and Engine Battery by plugging into the front leasure battery and using a cable with two cig plugs, one of which switched, to connect the cig plug on the kitchen unit (fed by the leisure batteries) to the front dash cig plug near the gear lever (fed by the engine battery).
https://vwcaliforniaclub.com/threads/leisure-battery-charging.32304/post-378239
sorry, this is the correct post :
https://vwcaliforniaclub.com/threads/leisure-battery-charging.32304/page-3#post-412885
I commented on the link. Looks a great solution for my situation. Thanks.
I have the Votronic MPP 165 duel fitted to the GC, this charges (prioritise) the leisure batteries first then the starter, when charged it trickle charges.
cheers
Thks Grumpy Grandad. Good point about fixing panels to the roof - then affects the overall vehicle height. I have not had the suspension lowered and don't want to given the amount of speed bumps around where I live. The other issue for me is making fixings onto the roof that might affect VW warranty (I have a 5 yr extended warranty). I am leaning toward a portable unit.
The Solar panel kits supplied by Roger Donahugh, a forum member, do not raise the height and fix in the Roof Rail fittings already on the California roof. There is No Drilling involved in fitting the kits and the vehicle height is unaffected. I have one of his kits for the past 6 yrs and regularly use 2 m car parks without a problem.
Just for reference the panels from Solar Camper Solutions bolt into existing roof channels so no warranty issues. Are also very low profile so lowering isn’t absolutely necessary.
The portable version that Calimili looks like a really good solution also if you’re not worried about ‘always on’ solar.
I really like the look of this solution especially since I don't really want to put a solar panel on my roof and it gives me the flexibility. My slight concern now is will there be import/custom duties/ extra shipping costs because we are ordering from Europe? That could push the cost up quite a lot. I have written to them to ask but I wonder if anyone has order similar type items form Europe in January and had any problems with extra hidden costs as a result of Brexit?
https://www.amazon.co.uk/dp/B07L11GSSZ/?tag=unique09f-21
https://www.amazon.co.uk/dp/B075NQQRPD/?tag=unique09f-21
There you go
Many thanks for the links, interesting. Unfortunately I think that is significantly more expensive. No doubt you are happily sitting in Germany without the problem we have made for ourselves here in the UK, you are the lucky one. Firstly the combined purchases are far more than the euro cost of the Offgridtec site and then I will still have to pay tax and the potentially huge additional courier admin fee on top since the supplier is still the same from Germany. I calculate that the rough cost including taxes and admin and before the shipping charges is £537 versus your original site cost of Euro 311 which translate into approx £275 i.e almost double the price!!. Looks like we will have to stop buying from Europe. Luckily I have bought almost everything I need for our van but a real shame for anyone trying to fit out their van from now on. I am also lucky to have a relative living in Holland (also in the solar industry) who travels to the UK regularly so will hopefully get it brought back via him??
You can get the controller via ebay and a UK supplier for £84 delivered.
Thank you that's really useful. I will update everyone with how I resolve the solar panel dilemma.
Hi - Solar Camper Solutions here.
The rear battery is actually very easy to access. You just need a steel ruler, or a paint stripper, or any other thin flat strong object to lever the battery up and then slide out. It's the 2cm lip that is the problem and lifting and sliding means it pops out easily.
The front one is easy too. 4 bolts, tip the seat forward and you have full access without unplugging anything.
We are shipping to the EU as before. There will be your local VAT and handling fee to pay when the parcel arrives in your country. Duty is minimal to zero depending on the country.
So I believe I have found the perfect portable folding solar panel from a UK based organisation so no problems with double VAT charging post Brexit and being charged courier admin fees which makes buying from Offgridtec prohibitive - see other posts on subject. It has the 120W panels with SunPower cells which are top of the range and the width of the panels open can fit nicely inside the windscreen which I see as a benefit since if you are leaving the vehicle in a public place you can leave it charging without worrying about it going missing. I also bought the 10A Victron MPPT Controller which is small and can communicate directly with your phone to give the relevant charging readings - this I think is a bonus since I previously had on my T4 solar panels a controller with a read out screen but I damaged the glass screen so I could not read it which was very frustrating. I didn't order the fuse and holder per the quote since I wanted to use a very small blade fuse which I am sure I can purchase from Halfords but I will show the link to both my order without the fuse and the previously draft order with fuse and holder. Mike at BimbleSolar has been really useful technically or if you are just ordering Laura is very helpful.
https://www.bimblesolar.com/index.p...cart&items=1846-1,1850-1,1938-4,2051-3,186-10,
https://www.bimblesolar.com/index.p...6-1,1850-1,1882-1,2037-1,1938-4,2051-3,186-10,
All I need to do is buy the fuse and holder, connect up the wires and I should be away...
That looks ideal, I'd be interested to see how you get on with it
F
5K
Roger Donoghue
Roger Donoghue
7K
markheathcote
markheathcote
G
11K
markanichols
markanichols
Gelato
15K
California_Ocean
California_Ocean
