OGII
I think your draft assumption is correct.However, the Wayfarer is a beast of a boat, and I'm not sure how easy it is to handle single handed. The GP14 is 36KG lighter, 50cm shorter and 10cm narrower.
Any boat this size will be hard to bring ashore and maneuver on your own, especially as most slipways are by definition slopes. I'd work on the premis you will always have help launching and recovering. You can solo sail these boats but the question is why would you, youd probably take a Laser out instead.
As much as the Wayfarer is a beast if you are serious about transits to the IoW and true coastal stuff I'd say the Wayfarer's size and stability is perfect, especially with the 2+2 crew. Much smaller and there would be no room to move, relax etc.
I spent a week day sailing off Leigh on Sea in a Wayfarer as a double hander and it was perfect for that tidal work. As ever see and try before you buy is probably sensible. Im sure Queen Mary or a similar local centre will have one you can use.
