Jabberwocky
Forever young (ish!)
I don't think that is correct.Air from outside a vehicle will be dry.
Air outside your Cali will always have some moisture in it. Its called humidity.
Moisture in the Air = Humidity
Water is present as a liquid and as a gas in the atmosphere. The amount of water vapour in the air is called humidity. The amount of water vapour the air can hold depends on the temperature of the air. Warm air can hold more water vapor, while cold air cannot hold as much.
Your home is 62% because of the moisture within it.For what its worth the Humidity forecast in London today is 91% (17:00 hrs) my home is 62% and in the Cali is 70%.
If outside is 91% opening all the windows means inside will increase to 91% once the temperatures equalise.Your home is 62% because of the moisture within it.
Go and take a reading of the moisture content outside and come back to me...
Infact.
Go and open some windows in the house for about 45mins.
I guarantee the moisture level in your house drops by some margin.
87% outside.Your home is 62% because of the moisture within it.
Infact.
I'd the interested in the maths of what humidity level would have been required in the space of a Cali to hold 2L of water.My van has sat on my drive a lot in the past year. Discovered it actually felt damp inside. Had dehumidifier running in it for 36 hours, pulled out around 2 litres of water so far !!
Dehumidifiers are brilliant things.
Good idea, had not thought of that.I'd the interested in the maths of what humidity level would have been required in the space of a Cali to hold 2L of water.
On the upside, the weather around your village will have been dryer than forecast...
I'd try closing all the dash vents.
