Frans_T5
For about three weeks ago I became a check cooling level message when I switched on the ignition.
So open the bonnet and yes the expansion vessel was almost empty.
It took about 1L coolant to top her of to the max indication line.
Removing the oil filler cap show me the worse, a big chunk of mayonnaise on the cap en the filler tube was white of sludge for more than 3/4.
This was alarming.
I drove the Cali to my garage en the discovered a leaking coolant pump
The previous pump was replaced July 2018, that year we had a broken oil cooler, and ending with a load of engine oil in the expansion bottle.
So the oil cooler and water pump has been replaced at that time and we have drove about 11000...12.000 miles before we ran in to the previous failure. Not much miles and another costly repair.
It turned out that a leaking water pump and blocked drain-hole causing coolant entering the crankcase.
Im my opinion this drain connection should be inspected and cleaned at each engine oil change!
It looks if the 2018 water pump has been fitted incorrectly and the QUAD-ring at the coolant side of the pump may got damage during that installation.
I hope the problem has been fixed for at least 80...100 miles more to drive.
This Cali has been quite a money pit, at 61.000 miles first coolant pump, at 77.000miles main shaft gearbox seized up due to a ball-baring failure, two mass flywheel clutch and gearbox overhaul, at 102000miles defective oil-cooler oil in coolant, water pump replacement , at 108120miles an other water pump failure.
So generally I'm not so happy with the build quality of our Cali.
Ours build 2006, 2.5l TDI AXD engine, 130Hp 4motion. Cost those day's 75000 Pounds (GPB)
I hope that many of us have more luck with their Cali's.
Yours,
Frans...
This was alarming.
Yours,
Frans...
