Cavilln
Hi
Hope someone can help me. We just returned from three weeks in France where we had to use bottled water as we discovered on day 2 that the waste pipe was leaking.
The leak is almost definitely coming from a rusty part of the waste pipe (in the lower left hand cupboard) just behind the waste stopcok tap (ie the red one that determines whether or not you dump your waste). Has anyone else had this problem? and is it easy to replace? If the whole section is available (ie the stopcock and the pipes connecting to it) then it looks like a case of just a few screw-thread fittings to replace.
also - and apologies in advance if this seems dumb - this same section also seemed to be leaking when we had a full tank of water but were not using the sink. it appeared that we were leaking clean water from the same place. or am i going mad? obvs the first step is to replace the leaky section and check it all our
finally, if too tricky to fix, where could i take it? I have a local (stockport) caravan fixer but the manchester van centre only does the mechanical bits
thanks
nick
thanks
nick
how old is your Cali , has it always been yours , by the looks of that pic my first thought is that it needs a lot of TLC!
