AndyWT
There is spec for toe in/out and camber in the workshop manual, all of which are to relevant PR code.Toe in and toe out. The arms dont appear to have chamber and nowt in the Workshop manual
Toe in/out is adjusted by and eccentric washer on the inner mounting securing bolt, if camber is out the bushes are shagged or it’s had a bump (which can also apply to toe in/out), but in the age old way camber can be adjusted by dropping the arm out and elongating the outer mounting bracket holes...
