I have just had the new VW 30mm lowering springs fitted to my T6.1 Ocean after a lengthy wait for the new revised springs.
It has definitely lowered by 30mm all round but the rear is 30mm lower than the front ( I measured from the centre of the wheel to the underside if the wheel arch) You can see it in the photo - so the van appears to be sloping down to the rear.
Does anyone know if this is correct ? The rear is not particularly loaded, most of our camping stuff is not on board.
I must say the handling around corners is vastly improved, there is just so much less bodyroll. It also doesn't appear to be much more 'crashy' over bumps.
