I
icic
Opened up the tailgate today and had a shock, loads of mould. A few weeks ago the blind stared smelling so took it to Dealer who said there was no leak. I decided to replace the blind anyway as it smelled so bad. Looks as though there still is a leak.
It’s a 2019 ocean so the break light issue should be fixed. Checked the seals and they all seem good. In the image there is a rubber bung at the base of the door, every time you open the door a bed of water runs out (and it’s not been raining for over a day) so there must be a leak somewhere, leaking into the door structure. There is no visible water entry apart from what comes out of the bung. I have put gaffa tape over the break light for now (does gaffa tape harm paintwork ?) Anywhere else’s might a leak be located at if it’s coming through that bung. Don’t think it will condensation as have been running a dehumidifier in the van while on hook up plus loads of ventilation. Anything else I should gaffa up, as can’t get to the dealer for 3 weeks. Or suggested Places to look for a leak.
