Ocean Spirit
Eating Ice Cream, skimming stones.
I am guessing like many I took the servicing plan when I bought my Cali that covers the interim and major service.
TBH, I never expected much from the interim service and just went through the motions. Also I have never really thought car services are value for money but this has more than confirmed that.
I have just booked in for the major and I am told I need to book a separate Brake fluid service as well at £54
Eh?????????
So I ask what I am actually paying for in that upfront plan. I reckon thats worth £100 tops I rang VW customer care and they are apparently very used to my enquiry.
What a rip off
Full service
We'll make sure to check the:
Lights (Wow check ? I can check them and do)
What a rip off
Full service
Horn (Wow check? I can check and I use it often enough which is the only real check that counts who cares if it works at the time of a service and not when you need it how you gonna prove they ever checked it)
Instruments (Wow check ? Surely only the the most oblivious people wouldn't know if their instruments are working properly and they are the ones who would likely not address it)- Washers and wipers and top-up fluid.
Tyre condition and tread depths (some merit if you really are that lazy I suppose but I don't need this)
Tyre pressures and correct them if needed (some merit if you really are that lazy I suppose but I don't need this)
Airbags for visible damage ( What?? how do they check that then)
Sunroof
Tipper system and change the oil if necessary
Paint and bodywork for damage and corrosion (and then what?)
Expiry date on breakdown set ( I have a spare tyre)
Engine and engine compartment for leaks
Condition of visible drive belts (Do they remove any plastic covers? and then what?)
Gearbox, final drive and rear axle for leaks and damage (Check only )
Manual gearbox oil level (Check only ?)
Final drive oil level (Check only ?)
Brake system for leaks and damage (Buy a brake fluid service before you come even if this is ok)
Thickness of the front and rear brake pads/linings (Finally something that sounds worth a few pence)
ABS sensor and cables (Finally something that sounds worth a few pence)
Underbody sealant and panels for damage (Then what?)
Supplementary rubber rings (So far as I can tell none have been disturbed so far)
Condition of the exhaust system (Then what?)
Steering joints and boot for wear and damage (OK)
Coolant levels and anti-freeze strength (just a check ?)
Condition of the camshaft drive toothed belt (OK)
Power-assisted steering oil level (OK)
Brake fluid level and condition (Buy a brake fluid service before you come even if this is ok)
ATF level (automatic) (Check ?)
Battery
Idle speed
Adjustment of headlights (check or check and adjust without further cost?)
Drive shaft (and?)
Run a vehicle systems test and read fault memories (OK)
Grease the front door check-strap and hinges (we'll see)
Grease the trailer coupling
Change the engine oil and filter
Renew the air filter
Renew the pollen filter
Renew the fuel filter
Perform engine basic settings (what could that be?)
Perform a road test
