SusiBus
2-pedal power Peppa Pig trike
How about suggesting they do a proper repair and replace the front panel with an aluminium one like they did originally.
"Mine was done one year ago. Corroded portion of front cap cut out but cap not removed, since the cap is only the small visible part of a structural piece which extends down the sides to reinforce the roof, and VW has deemed replacement too expensive."How about suggesting they do a proper repair and replace the front panel with an aluminium one like they did originally.
That'll be my next step if this cowl fix fails.How about suggesting they do a proper repair and replace the front panel with an aluminium one like they did originally.
Oh, and VW only pays for full repair and paint if the van is less than 7 years old.I am still waiting for mine to even start the process!!!!!! It’s been about 7 years I have been waiting!!
I took my 2008 California to VW Preston in 2014 to be told that my van was 6 weeks older than the 6 year guarantee offered by VW but given their record on problem solving I should not have been suprised. So I've ignored the paint blisters and just given them the occasional polish. What is this 7 year cover about? Ive not read all the 211 pages on this issue!
Apparantly the Front panel alloy was changed for MY2014, if you believe that. My 2014, MY2015 is clear.So do newer vans have a different roof design, or, is it likely to happen to all VW roofs over time?
I believe the extension for the front panel was 6 yrs from 1st registration, but you are eligible for the recall relating to the edge “ corrosion “ on the Elevating Section.I have some corrosion on the main part of the roof on my MY2013 SE which only appears to have emerged over the last 8 months. Can I still get that looked at by VW?
But they will only apply the clear tape for free. The paint repair will be at your expense.I believe the extension for the front panel was 6 yrs from 1st registration, but you are eligible for the recall relating to the edge “ corrosion “ on the Elevating Section.
I don’t think so, in the U.K. if there is corrosion present on the edge of the elevating section, minor corrosion is dealt with at the Dealership and major at a body shop before the tape is applied. There is No Cost for any repairs required.But they will only apply the clear tape for free. The paint repair will be at your expense.
@TripleBee I didn't pay for my paintwork repair ... On my 2010 Cali I had the elevating roof edge corrosion done in August, lots of corrosion under the seal so the bodyshop got additional VW approval to remove the whole roof for a total respray, fit edge tape and new rubber, great job that took 4 weeks (including a week for VW to approve the full respray) and NO COST TO ME.Oh, and VW only pays for full repair and paint if the van is less than 7 years old.
So you will be paying for the paint repair.
Yes, SMC should sort you out.Forgive my ignorance on all this, but if I want the corrosion looked at, presumably I get in contact with my nearest VW dealer specialising in Calis? In my case, SMG Tonbridge.
What is it you mean by the main part of the roof? The roof corrosion problem was mainly under the rubber seal and the front panel.I have some corrosion on the main part of the roof on my MY2013 SE which only appears to have emerged over the last 8 months. Can I still get that looked at by VW?
Don't confuse the 2, separate problems.2014 T5 California.
Having read the feedback from everyone who has been affected by the corosion issue and the nightmare of trying to put it right, the million dollar question is if there's currently no evidence of corosion, how likely is it to occur?
I've read that this issue was rectified in 2013 (?), however it appears that owners of newer models are still experiencing the problem.
If it does occur, what are our options and is this an unsightly visual (paintwork) issue rather than a structural one? The thought of joining a lengthy waiting list and endless correspondence with the local dealer is not the experience we've been dreaming of
Thank you for your advice
Have you gently pulled down the rubber seal around the roof edge to see if the paint is bubbling underneath out of sight? I hope it's not, but I didn't see it on my 2014 Beach until I looked under the seal in 2018. What I saw made me check the front deflector very carefully, and a small spot was emerging above the windshield. So, both roof and deflector were affected. It was more visual than structural but with the passage of time would have gotten worse. I suppose that the difference in my case is that a month after taking it to the VW agency in Barcelona, the repair was authorized by VW Germany and under way without charge. I honestly think the years of waiting lists in the UK are not real and a simple tactic to avoid doing the work. As far as I have been able to read on Tx.de, Germany, where my van spent its first 4 years, doesn't have these waits of years. Considering the problems many have had with the repair, there's a good argument for skipping VW entirely and having the paint corrected at a good body shop, and then dealing with it again after a few years when it comes back.2014 T5 California.
Thank you for this helpful reply.Don't confuse the 2, separate problems.
Front Panel, above windscreen, corrosion Apparantly fixed MY 2014 with change in alloy used.
Elevating Roof section with corrosion under, and due to, rubber and metal edge seal, Not Fixed. However, from My? 2017 a plastic edge tape applied, in factory, under edge seal.
All, Californias from 2010-2017 can have have this tape applied and any edge corrosion repaired free of charge.
