Engine fan over run on T6.1
Abergavenny
T6.1 Ocean 150
The engine fan on my 2020 T6.1 California Ocean continues to run very noisily for over 5 minutes after turning off the ignition. This happens on both long and short runs - is this normal ?
Is it every journey? if not then it's regeneration not completing.
The ECU doesn't know how far you intend to drive so I often find that it will start a regeneration just before I get home and then will do one next time I go out but not until it is up to temperature so you can get into a cycle of a regeneration every time you go out.
I have learnt to feel when it is doing it now and if still doing it when I pull up I keep the engine running on a fast idle until it finishes.(you hear a very slight lift in rpm and when you take your foot off, the tick-over has returned to 950, let it tick over for another minute and you don’t get the fans going mad)
I think it is every journey but will double check. What is regeneration? Cheers
The vehicle is fitted with a Particulate filter that slowly fills up with soot and this has to be burnt off otherwise it would get blocked up.
The Engine Control unit uses a differential pressure sensor to measure the difference in pressure between the inlet and outlet. When it reaches a certain level of blockage, it runs a cycle that injects fuel in the exhaust cycle and heats up the turbo and the particulate filter to about 700deg where the build-up of ash is burnt off.
During this cycle, the tick-over raises from 950 to about 1000rpm and the engine feels a bit rough.
See page 28 of the attached.
  • SSP__564__The_2_0_litre_TDI_engine_in_the_T6.pdf
A recent conversation with a VW Assist technician about looking after EGR suggested looking out for idling revs of around 1100 rpm at the end of a journey. If so leave the engine running or drive around the block until they drop back to normal when the regen will have finished naturally.
The vehicle is fitted with a Particulate filter that slowly fills up with ash and this has to be burnt off otherwise it would get blocked up.
Very close, but it actually fills with soot and then this is burnt off leaving a small amount of ash.
The ash gradually builds up, but once full the filter has to be replaced (dealer) or removed and backwashed by independent specialists
As Loz says. Search ‘hovercraft’ mode here for more info.
The regen seems to work via the satnav, it always kicks in as I pull onto my drive
Try to set your destination a few miles earlier. Maybe your regen will be ready when you are home then?
Yes I knew that but, I was trying to keep it short and simple.;)
I did a seven March journey this morning and when I got to my destination and switched ignition off, I’ve could hear a fan running wasn’t sure if this was a region or not it also smelt quite hot. I checked to make sure there was sufficient coolant and the cooler bottle was full. Can somebody confirm with this that your region? Cause I’ve never actually seen it happen before and how can I confirm it was actually completed?
Do you recall what RPM tickover was at the time?
If you have a carista you can download the DPF MONITORING app. You can see everything you need to know on that. Soot levels. Last time regen was time and distance. And if it’s doing a regen at that moment. I use mine all the time very useful app.
No I didnt notice the face running until I turned it off and got out
I do have a Carista does it require my to activate a subscription to check ?
No. The app uses the carista devices as a Bluetooth connection.
I will go and check later this morning - I guess you just need to pay the subscription to make a change any idea which menu its under and does the vehicle need to be running ?
You just need to use the carista as a connecting device you don’t actually need to use the carista app just the dpf app that you will need to download from the Apple Store. You select the engine code in the dpf app that matches your van and that’s about it. Very easy when you get the hang of it
ok which dpf app
If you're on Android this app also work great to monitor the DPF with Carista or Vgate iCar 2 Bluetooth etc. OBD2 dongle.
