Stuarty
Hi everyone,
Hope you are all doing OK. I was wondering if anyone could help me with a problem I’m having with my T6 VW factory fitted detachable towbar please? I haven’t really fitted it that much, maybe 20 times, but recently I’ve had difficulty getting it to latch into the socket on the Cali. When I insert it, the knob won’t rotate fully back to the green safe position so I am able to lock it and use it.
I’ve tried lubricating it, but still no luck. It seems to be that the single pin that releases the locking mechanism isn’t getting pushed in far enough. If I push it in using a pair of pliers, it releases OK, but it does take a little bit of effort.
Has anyone else had a similar issue, and come across a solution please?
Thanks in advance.
Cheers!
Thanks in advance.
Cheers!
