Brendon
My T6 is in the garage again due to a dropping roof on the offside. Originally, we had a problem with the roof dropping in November 2019. Unfortunately, it seemed to 'fix' itself on the way to the garage and they were unable to recreate the fault. The vehicle was under warranty at the time. Since then we have had no issues with the roof until our two week trip to France in August where the fault came back. This was a bit of a bind as we were hoping to use the roof space for sleeping etc. so it put a bit of a dent in the holiday.
Anyway, I've spent a bit of time going through the various threads covering roof issues in an attempt to self diagnose the issue. Not that I was planning to undertake the works myself, but I wanted to make sure the roof fault was correctly identified, that I didn't get a re-occurence of the fault, and that I don't end up spending a fortune whilst the technician swaps out multiple components without applying any thought or logic.
Currently, the garage wants to replace the offside ram as "80 to 90% of roof faults are due to a faulty ram." Personally, I'm not convinced: here's my reasoning....
1) The ram is a passive device. Oil is pushed in at one end and the ram goes up. A faulty ram seal would cause the roof to drop over time. However, once the seal fails it doesn't then fix itself for 9 months before going wrong again.
2) When you raise the roof fully and then lower it immediately the faulty side drops much more quickly. A leaky ram seal would not have had time to leak so the roof should lower on both sides equally.
3) Regardless of how long the roof is up, or whether you jack it up prior to lowering, the dropping side lowers more quickly.
4) The roof drops quite quickly. About half way in under 30 mins.
To my mind, all of this points to an error with the hydraulic pump/valve set inside the cab. As I understand it, there are two valves and actuators that control the flow oil hydraulic fluid into and out of the rams. If one of these valves was not working correctly, perhaps not shutting down properly, fluid would leak back out of the ram and the roof would drop on one side. Also, if the valve was more open on one side than the other, the roof would not lower on both sides evenly.
Does any of this resonate with anyone, or am I talking rhubarb?
As the vehicle is only just over three years old I am angling for VW to take the bulk of the cost of repair under warranty, particularly as the fault had already occurred under warranty. Am I being too optimistic?
Any thoughts gratefully received. Thanks.
