a892374923874
Try this..........Done a wash with the snowfoam, 2 bucket shampoo, and the Polarseal. then dry with a drying towel. Results are good enough for me. Thanks for the pointers!
What's good to clean the wheels? Ideally a spray on, wash off with minimum faff!
Cheers
Thanks. Is this strong enough for wheels that would only be cleaned twice a year or so?Try this..........View attachment 66022
You'd probably be better off with a dedicated alloy wheel cleaner (not the horrible acid type) as it will break down the baked on brake dust without dulling the wheels. I use Bilt Hamber Auto Wheel (ph neutral), but Autobrite Direct Purple Rain or Maguiars Ultimate all wheel cleaner are equally as good.Thanks. Is this strong enough for wheels that would only be cleaned twice a year or so?
You'd probably be better off with a dedicated alloy wheel cleaner (not the horrible acid type) as it will break down the baked on brake dust without dulling the wheels. I useBilt Hamber Auto Wheel (ph neutral), but Autobrite Direct Purple Rain or Maguiars Ultimate all wheel cleaner are equally as good.
I've not used Autoglym Polar seal so can't really comment. Not sure if it's like the Bobby Dazler stuff people use on great whites and caravans?Next question:- I got a Kent care microfibre drying towel because it was only £5.
I sprayed the Polarseal, then immediately rinsed it all off with the pressure washer, then dried straightaway.
It took a lot of going over and towel wringing to dry it, and I suspect there may be some water marks. Would I have been better to air dry for half an hour then go over with the towel?
I used some triplewax shampoo that's been languishing forlornly in the garage for probably 20 years.Did you use a wash product with a wax
Thanks, I've just ordered a litre of this to try.hamber auto wheel cleaner
Ha, ha! I too have a concoction of different washes, waxes and oils from various stages of vehicle ownership.I used some triplewax shampoo that's been languishing forlornly in the garage for probably 20 years.![]()
1. I wouldn't recommend it, even if it were a brand new uncontaminated leaf blower that was dedicated to car use only and kept in a plastic bag when not in use, you could risk blowing dust etc from around the vehicle up onto the paintwork. Then when you towel it and polish it you'd be grinding said dust and grit etc into the paintwork. A used one would be full of garden crud sucked in whilst being operated in the garden.Just given the van a snowfoam, 2 bucket wash, Polarseal, and towel dry. Last time was last August. Some questions arise!
Cheers
- Is there any downside to using an electric leaf blower instead of a towel to dry after applying Polarseal? Something has eaten my drying towel over the winter so I would need to get a new one.
- The paintwork feels a bit bumpy/rough with tiny spots below door handle level all around. Is this where clay comes in? Clay bar, Mitt, Spray solution? Would I just apply this where it feels bumpy? Which one is quickest?
- Do I need fallout remover?
