ArunAlec
Or even if the seat does not fit....As the saying goes.....If the cap fits......
This goes for everything in the van...We had our leisure batteries fail at 3 years...We had our awning come apart in 3and a half years. We had our roof repaired at 3and a half years...We are lucky many people have had many worse things happen compared to to us.. Don’t even think about bringing legal action against a company as big as VW because you’ve go no chance...You have more chance getting something done if you don’t threaten them..Blaming the owners for these breakages is a cop out. Any reference to the weight of the occupants is rather beside the point. These chairs are designed to fit in with the California lifestyle and within reason, they should be fit for purpose for a wide range of owners sizes and weights reflecting their customer base.
The problem we are discussing here is the failure of a cheap plastic component that forms the lower part of the joint that connects the front chair frame to both arms. This component slides inside the front chair frame tubing and is secured by a rivet. The failure is always as a result of the weakness caused by the rivet hole in this cheap plastic part. If you think about it, this part is not load bearing and I suspect that it's premature failure has more to do with the way chair is used. Never the less, they should not break. IMO they only do so because of a poorly designed part costing tuppence ha-penny. Further more, I suspect that if there was no rivet hole and instead this part was bonded to the tubular leg, the problem would be resolved. Alternatively the manufacturer should use a different material.
I rarely use these chairs as I don't find them comfortable. Instead I either rotate and use one of the front seats or use one of our two fold up picnic chairs which I purchased from a motorway service station about twenty years ago. From memory they cost £15 each and are still as good as new.
The average British man is 5’9” and 13 stone 2 pounds (83.6 Kg).Some have admitted to being heavier than 75kgms and the upper bed is supposed to have a maximum weight capacity of 150kgms, so I presume the chairs might have a similar restriction/chair.
Do you really think that VW would defend a small claim for a £120 picnic chair that probably costs them under £10?Don’t even think about bringing legal action against a company as big as VW because you’ve go no chance...You have more chance getting something done if you don’t threaten them..
Correct. Upper bed has weight limit of 150kgms for 2 people + a probable safety margin. Likewise the seats I would have thought.Blaming the owners for these breakages is a cop out. Any reference to the weight of the occupants is rather beside the point. These chairs are designed to fit in with the California lifestyle and within reason, they should be fit for purpose for a wide range of owners sizes and weights reflecting their customer base.
This issue has been reported too often to be dismissed as purely sods law. A picnic chair costing £120 should function as a picnic chair and should continue to do so. If it doesn't because of a faulty joint and then it isn't fit for purpose. Just because this issue is not happening to most seats doesn't mean there isn't a design fault.When you say a design fault then it should be happening to most of the seats. It’s not so not a design fault.
Something fails or is broken and immediately its “ a design fault” and “ not fit for purpose “ . No, it’s just Sods Law. Things break or fail and hence a warranty, but occasionally it happens outside the warranty. That’s life.
Hey Marc kan je me het adres doorgeven waar je deze set bestelde, ik heb namelijk hetzelfde voor.A member at the German Caliboard.de has built these bolts for repairing the arms:
https://www.caliboard.de/uploads/mo...humb.jpg.80e7529c1539be9138688a8073be6069.jpg
I ordered a set (4 for for both chairs) at 30 euro and put them in the van just in case the poor designed plastic construction fails. Maybe I replace them anyway, before tumbling on the campground.
You can only see the pictures on the site above after registration (worth to do that, they are very well informed). If I receive the bolts next week I can post a picture.
Regards from Amsterdam,
Marc.
I'm interested in a set how can I send private message?Hey Cali Fans,
here some more pictures...
Are you interested send me a privat message.
Greetings from Germany
Domi
Do not think the FOIA will help. The Freedom of Information Act 2000 is an Act of the Parliament of the United Kingdom that creates a public "right of access" to information held by public authorities. It is the implementation of freedom of information legislation in the United Kingdom on a national level.My next step was going to be using a 'freedom of information request' about the number of these chairs that have been replaced under warranty. That would have been interesting if they have that data. But like a lot of people I'm just going to replace it.
The photo is slightly blurred, is it not the other end of the rivet? Can you not tap the rivet out with a centre punch or similar from the drilled side?Well both my ocean chairs have now failed at the same spot . No warranty. Going to attempt a fix myself but how do you undo this pin? I've already drilled out the rivet
I can get it to turn but cant stop the other end spinning as it's too flat. I thought it was like a pin and a special recessed nut. Is it just a rivet? If so I'll have to drill it. Problem is if you replace it with a nut and bolt the chairs arm won't go over the head of the boltThe photo is slightly blurred, is it not the other end of the rivet? Can you not tap the rivet out with a centre punch or similar from the drilled side?
Sorry, I thought you said you had already drilled out the rivet. I’m unfamiliar with this connection. Your photo is still blurred, is that a Torx screw where your screwdriver is? If it is, cut a slot in the other side with a hacksaw and then you can hold against it with a screwdriver.I can get it to turn but cant stop the other end spinning as it's too flat. I thought it was like a pin and a special recessed nut. Is it just a rivet? If so I'll have to drill it. Problem is if you replace it with a nut and bolt the chairs arm won't go over the head of the bolt
i drilled out the little pop rivet already yes.Sorry, I thought you said you had already drilled out the rivet. I’m unfamiliar with this connection. Your photo is still blurred, is that a Torx screw where your screwdriver is? If it is, cut a slot in the other side with a hacksaw and then you can hold against it with a screwdriver.
Sorry, we’re talking at cross purposes. I don’t know how that pin comes out, it looks quite substantial. Angle grinder? File? VW probably have a special tool for it!!i drilled out the little pop rivet already yes.
vw would just replace the whole chair. looks like i'm going to have to drill it and find something to replace it withSorry, we’re talking at cross purposes. I don’t know how that pin comes out, it looks quite substantial. Angle grinder? File? VW probably have a special tool for it!!
Hi, I had a chair fail at the same point a few weeks ago (2016 Cali) and ordered a set of 4 replacement parts from Domi. Very happy with the quality but took a while for them to arrive even after he notified they had been sent.so you do have to drill out that pin ?View attachment 64440View attachment 64441Hi, I had a chair fail at the same point a few weeks ago (2016 Cali) and ordered a set of 4 replacement parts from Domi. Very happy with the quality but took a while for them to arrive even after he notified they had been sent.
The bolts he uses have very thin heads and nuts so they fit within the space inside the arm rests.
Apologies for the quality of the photos
