Bulb Gone
nickdrums
nickdrums
Coleshill
T6 Ocean 204
Hi all,
My “ bulb gone” warning light is showing, and it seems to be the driver side bulb shown lit on the passenger side in the attached photo. Any clue on what that one is called and how to change it? I’ve had a look at my manual and it was most unhelpful!
Cheers, Nick.
Hi all,
Cheers, Nick.
Hi Nick .
I’m guessing they are not the LED highlights?
Surely it gives the bulb type in the manual?
Mike
Isn't it just a simple, single bulb 12V/21W with bajonet? BA15S
To change it, you might have to take out the air filter housing completely, or pain your hands trying to fiddle between the headlight and air filter housing.
No not LED. The manual does obviously describe the lights, but you sort of need to know what that one is called. Is it the running light? It’s the one right at the bottom of the cluster.
If it comes on automatically when the engine starts, then Yes, Running light or DRL (Daylight Running Light).
Almost - the warning light doesn’t come on immediately. I think those lights come on when you first turn the steering wheel?
Most DRLs come on with ignition. The Dash warning light will be slightly delayed as the vehicle checks all the circuits.
Y
Perfectos
Perfectos
Jolberg
Jolberg
Jolberg
bmassaer
10K
bmassaer
bmassaer
bigmac77
jessecampervan
jessecampervan
