Name and shame!My California has undertaken the warranty roof repair on the elevating roof. Corrosion around the edge. The repair was poor! Goodness knows what they did but grey undercoat coloured paint was left showing around the edge of the seal in places. (And they created a very small dent on the edge of the roof!!)
Volkswagen Customer Services have concluded that a new roof seal will mask this paint as the old one has shrunk.
The Cali is booked in for this to happen.
How is the seal fitted! Is it in one continuous piece And slipped over the roof Or is it joined?
I really don’t want to find they’ve messed this up as well!
Rob let me go and sleep on it a few weeks to see if i liked it , in the end the blue colored canvas was changed again....
You would need to ask VW that one, VW were obviously trying different methods at the time my van was done as some got the tape only. It would be interesting to know the effectiveness of the repair methods after 3 years but I suspect VW would not share that information.Why aren't the seals stuck on when new, if it stops water ingress?
Back in 2013 only 4 repair companies were being trained and authorised by VW Germany to carry out the roof repair. Which company were you assigned to?I’m still waiting for mine. I informed them after the first VW California meet in 2013! I had a letter through but don’t seem to be able to contact the company!
I was informed of corrosion on my roof two weeks ago, and the main dealer told me there are now only two bodyshops authorised to carry out this work.Back in 2013 only 4 repair companies were being trained and authorised by VW Germany to carry out the roof repair.
Hi there, was it Witherspoon motor services in ravelston place? I’ve got the same issue on a 2010 Cali I’ve just purchased and live in Musselburgh so thought I’d try the same company if you had some success with themJust wanted to add some good news to the thread. Following advice I received a few weeks earlier about corrosion on the front panel of my van, I took the van into a body shop for repair. As far as I can tell, Witherspoons in Edinburgh did a great job. I've posted before and after photos of the repair. Total cost under 400 pounds.
View attachment 40815View attachment 40816 View attachment 40817View attachment 40818
Yes BUT it depends on the age of your vehicle, 2010 onwards are covered, And whether it's the roof front cowl or the roof edge that requires repair. The current recall is form the edge of the roof around the rubber seal. Ask your dealer whether the front cowl is still covered if that's your issue.Without wading through 207 pages on this issue can anybody confirm if VW have now completely accepted liability for all aspects of roof corrosion and that it is a question of reporting the issue and VW effecting the repair.......or is it a case by case fight?
Would just like a simple yes or no so I know which route to take.... nice or nasty
Thank you
Yes BUT it depends on the age of your vehicle, 2010 onwards are covered, AND whether it's the roof front cowl or the roof edge that requires repair. The current recall is for the edge of the roof around the rubber seal. Ask your dealer whether the front cowl is still covered if that's your issue.
As I understand it, for T5s. All roof corrosion (Front cap and main roof) covered under a “special Roof only“ extended warranty up to 6 years. I think @SusiBus was the one who got the written acknowledgement of this cover.Without wading through 207 pages on this issue can anybody confirm if VW have now completely accepted liability for all aspects of roof corrosion and that it is a question of reporting the issue and VW effecting the repair.......or is it a case by case fight?
Thank you
VW may extend beyond the 6 years, my 2010 Cali has been approved by VW to have the roof edge corrosion repaired after the recall for the roof seal corrosion check. The cowl corrosion was repaired by VW with the previous owner.As I understand it, for T5s. All roof corrosion (Front cap and main roof) covered under a “special Roof only“ extended warranty up to 6 years. I think @SusiBus was the one who got the written acknowledgement of this cover.
