W
Wezza
Hi, I have read many of these threads but havent seen the exact problem.
I am looking for advice on a VAS 6161 battery test result from VW that read 'Good-Recharge' even though it loses charge when left in the van over 1 week with no devices on (control panel reads 0.2A when switched on). VW won't accept my multimeter readings and therefore won't replace the battery under warranty. Is this VAS6161 test robust?
Many thanks in advance for any insights, Wezza
Background is as follows: I bought a 18month old T6 California Ocean in March before lockdown from CityGate Colindale (mileage only 1000 so been on forecourt for a while). I noticed during purchase process that the leisure batteries had been on 0% on a video sent to me before purchasing. When I picked the van up they had been charged and was reassured that they were fine, and if not then they would be covered by warranty. Drove home and batteries down to 80%, and then lost 10% per day till flat (0%). Recharged and same thing happened (multiple times).
Reading these forums it became clear that the batteries could be irrevocably damaged if left on forecourt with 0% for long period). Citygate told me to book into my nearest Van Centre (SMG Tonbridge) where the batteries would be investigated and replaced under warranty if faulty.
Then COVID lockdown happened and all the garages shut. When they reopened I took the van in and the garage got the batteries tested (results attached). They replaced the battery under the seat which reported a fault but not the one under the wardrobe ('rear') as the test read 'good, recharge'. They had charged the batteries before the test so the fact that this second battery was already down to 11.95V when tested is consistent with what happened on my drive. SMG say they cannot replace this battery under warranty as result of the VAS6161 says the battery is good. It still loses charge.
