G
GrumpyGranddad
Guest User
Has anybody added an additional 240v socket to a T6.1 ?
Why?Has anybody added an additional 240v socket to a T6.1 ?
Was considering fitting a microwave In a cupboard.What are you thinking of powering with it please?
Yes in a different position - inside a cupboard.Why?
Do you want to run more than 1 mains appliance at a time?
Or do you want a mains socket in a different position?
I use something like this in my T6, not sure how different the socket layout is in the T6.1
Not what I’m looking for but looks useful. Might get one
Which cupboard?Yes in a different position - inside a cupboard.
Brilliant, many thanks.Very simple to do, if you’re ok with lectrickery? Just access the circuit breaker (not sure where it is on your model) and you’ll see the out going wires to the existing socket. Just pop your new flex (2.5mm2/3 core) into the same terminals. Run the flex to your new location and mount the new socket. Bosh.
In an ideal world you’d then test it for various RCD functions but you’re unlikely to have that kit. Obvs a pukka spark will.
Remember Campsite mains supplies can be as low as 6 amps, and some of that will be taken to run the Mains Charger. So be aware of your power requirements.Brilliant, many thanks.
My surname is Sparkes so need to get pukka’d up
Thanks for that. Have just ordered one !
Just resurrecting this thread as I want to add another 240v mains socket.Has anybody added an additional 240v socket to a T6.1 ?
Dont suppose you have any photos of the location..?We had an additional one fitted to our old beach. Located in the boot, used for the fridge + easy to run extension out to an awning (just shut the cable in the boot).
Where would you be using the 2 x Mains powered devices.?Just resurrecting this thread as I want to add another 240v mains socket.
We often use two mains powered devices and have a two way adaptor that plugs into the socket at the end of the sink. However, I'd like a more permanent/elegant solution and wondered if you had found a suitable location/solution for an extra socket.
I'm aware of the power limitations etc of campsite EHU power, but many larger motorhomes have multiple 240v sockets so it is certainly doable.
Yes, in the kitchen would be preferred. I wondered if there was a replacement socket that was similar to the OEM one but with two sockets.Where would you be using the 2 x Mains powered devices.?
If the kitchen unit then why not put a 2 nd socket below the original
This would be neat.Yes, in the kitchen would be preferred. I wondered if there was a replacement socket that was similar to the OEM one but with two sockets.
Indeed, I have one of these ( a 2 gang version) buts it's not 100% secure so would prefer a proper 2 gang socket.
