F
Fost@T5
Hi...Had the same problem. So i was charging a 120Ah (20 Kg) battery in the flat and bringing it down to the Cali , connect an inverter to it, and plug the van into the inverter connected to the battery. Usually the inverter would cut off after 3-4 hrs therefore I had to repeat the process for three to four times, until the display would show 13.1 V with 0.1 A coming in.
It works, but you need invest 400 quid for the extra battery, inverter and charger.
After 8 months I got fed up of bringing up and down the flat the 20 kg Battery and the inverter, although i developed strong biceps in the process.
Now I have a portable, foldable 120w solar panel with the mppt victron 75/15 charger connectet via Anderson plug to the front L battery. the panel is layed on the dash against the windscreen. Now the leisure batteries are topped up once a day with no effort.
I would also like to use a portable Solar Panel, but why do you need a charger?
I thought the Solar panel was charging the battery?
Excuse my ignorance wrt electrics!!
