The metal strip/handle of the blind has a plastic, black on mine, insert in each end, just a push in fit, that fits around a wire that runs in the side slot on each side. Are these properly positioned or has one popped out and jammed on the wire?Please help, my blind on sliding door is well and truly jammed about 5 inches from top, pulled as hard as I can to try and make come down and it’s stuck, please help
Trying now
Nope
How does plastic trim around it come so can fix?
| № | part code | title |
If it is jammed and you think there is no alternative but replacing, I would be inclined to get a piece of wood along the bottom blind pull strip and tap the end that is lowest, upwards to straighten the blind up. It might work and you don’t really have much to lose.Sorry, yes just looked but dosnt really show any clips holding (37) part, or how easy to remove
Yes, upwards to straighten it.
So both ends of the blind will go up?It lifts up easy but won’t roll up, the blind seems jammed in middle
