Yeas it clears the steel wheels where the ugly hub nut is exposed.
Its a bit hit and miss, what I did was measure the internal dia and the external and then searched Fleabay for ones that matched the dimensions.Hi, thanks for the info. Can I ask which cap you used as I'm trying to find a solution to help reduce rusty water running onto the wheels.
Much appreciated,
Mark
Pushing calliper pistons back to fit new pads can cause air to be drawn into the brake line, this can work it’s way into the master cylinder and you could lose partial braking, plus the excess back pressure can damage the abs pump.
Where did you get this from,Although forums are very good at sharing views and supporting with problems with our vans, there comes a point where certain jobs should be carried out by qualified technicians. I have been teaching automotive for 25 years, fully trained and qualified although everyone seems to want to have ago without the knowledge of what could possibly go wrong. My advice to anybody who is deciding to branch into home mechanics, wait, think about what you are doing. Get it wrong and a vehicle could possibly injure or wipe out an entire family especially if brakes are done incorrectly. Pushing calliper pistons back to fit new pads can cause air to be drawn into the brake line, this can work it’s way into the master cylinder and you could lose partial braking, plus the excess back pressure can damage the abs pump. Your cheap job could end up costing you more in the long run and don’t just mean financial!
I agree here. Never heard of air being drawn in pushing the pistons back.standard procedure on all calipers that. I've always fixed my own brakes. If you have to tell people not to put their faces under Van's sitting on bricks then these same people shouldn't be changing their own brake discs. Here's a good mechanics quote for you all to keep safe... 'never put yer finger where yer wouldn't put yer cock' .Where did you get this from,
The pistons are being pushed back not sucked back, on disc with handbrake the piston is pushed and screwed back to reset the auto adjuster, check with Lucas, ATE, Bosch etc, this is standard procedure, some are more complicated requiring diagnostics to be plugged in to reset adjuster/wear sensor.
Maybe this is why today’s auto techs don’t know anything practical only where to find the ODBC socket.
25 years... I retired 5 years ago after 30 years at the heavy end of the VW empire and one of my many responsibilities was training the emerging markets in Southeast Asia for 16 years.
I recently changed my rear discs and pads.Parts came from ECP the last time they had their 35% discount code, kept them in stock as I knew I would be changing them soon.
Lovely and shiny, as they should be. I find it’s lack of use (leading to corrosion) which causes the need to replace brake discs. I haven’t changed discs for years because they are worn too thin! I clearly need to get out more, driving that is!Those are mine. Used as daily driver.
I wouldn't say lovely, and not shiny too.Lovely and shiny, as they should be. I find it’s lack of use (leading to corrosion) which causes the need to replace brake discs. I haven’t changed discs for years because they are worn too thin! I clearly need to get out more, driving that is!
