T
TheSmiths
- Messages
- 3
Hi there.
I see that some members - Camper-x etc.. - have tackled the Cali fridge task previously via some of the threads on this site.
I need to do the same thing.
I had a go tonight, but wasn't sure I could just lift it out - so I stopped.
I found 6 bolts retaining bolts on the short side of the box - 3 under hob and 3 in wardrobe.
I could disconnect the wiring looms ok within the cupboard.
I managed to wiggle the fridge box up about 8 inches or so, but it didn't look like it would fit out before I run out of headroom (I had the roof down, which probably was a mistake I realize now - with the roof up there is probably enough room).
But the curvature of the window etc.. looked like it may jam the upward progress of the fridge.
Anyway, I backed off and thought I'd check this site before going on.
It may be a tight fit, but if you raise up the roof, and wiggle it about, are you able to squeeze out the fridge with the kitchen area left insitu ?
I'm hoping you can, as dismantling the whole kitchen are looks a nightmare - as it's full of pots and pans etc..
Reason for asking is that our fridge is dead.
The penguin diagnostics video are useful to indicate why - www.penguinfrigo.co.uk
But alas the compressor controller has 5 flashes on the diagnosis indicator, which means it's probably burnt out, and something else in the cooling circuit has probably caused it. Which also needs fixing.
So not sure yet what to do about that, but the whole thing needs to come out to take the next diagnosis steps.
Craig.
Craig.
