Anthony1
Too young to be old
- Messages
- 1,350
- Vehicle
- T5 SE 180
You're brave !!!
Someone on here once posted the following link, which not only tells you the prices but also the height restriction:
https://en.parkopedia.co.uk
I've saved it as a favourite so I can quickly check my options if I'm going somewhere new.
I have parked in all of the central Brighton ones marked as 2.0m on Parkopedia, and had no issues in our Cali.
I presume now we've left we'll be going back to feet and inches........Our local tesco just covered up all the metric measurements for some odd reason, I guess someone hit something they shouldnt have been able to hit?
Always feels close in the cali even when you've got 10cm clearance.
Whoever gave you that information at VW is wrong.I was told I need 2.1 absolute minimum as the awning takes it over 2m. Measurements came from VW. Got my roof scratched going under a 2.2m last year so would never risk a multi storey.
The sign in my photo says it is the maximum height, which is weird. I didn't really pay attention at the time. As long as I can get under the bar, I will give it a go.If the barrier says 2.0m then you are fine as it takes the slopes etc into account; The height bar relates to lowest point in the entire car park (often a water pipe or some overhead ducting)
Mine absolutely won’t go under any 2m height barriers around me. I’ve tried numerous sites and it won’t go without scraping the roof.Whoever gave you that information at VW is wrong.
The T5, T5.1 and T6 fitted with the VW awning made by Thule Omnistor is under 2m, provided it is fitted with VW wheels and the correct tyres.
The standard awning is no higher than the centre point of the roof which is concave in nature.
I also have a Solar Panel on top and have no problem parking here. 2M Limit.View attachment 55057
All standard but as that says it’s 1.99m and given uneven ground and inaccuracies, I’m not surprised it won’t fit.Standard wheels and suspension? Likewise Thule/Omnistor awning?
According to VW it should fit. Measurements for a 2005/6 California.
