2into1
Née T4WFA. Now without Cali :(
I'd also advise those reading this and wanting to be aware of the risks... That VW's measure of when oil consumption becomes unacceptable is something like 1L per 1000km (620 miles). They seriously say that is you are doing 650miles to the L of oil then you are fine!
So with that ridiculous 'rule' in mind, there is a risk that their 'acceptable' compression levels might (might... I don't know) be equally ridiculous.
I'd want to see how the compression levels of 'my' engine compared to real world examples of healthy engines, not to a figure VW have chosen to be acceptable.
(to those getting lost, the theory is the EGR cooler fins corrode and deposit diamond hard particles in the engine sump. Those particles get stuck in the piston rings and wear the cylinder bores terribly. (shows as low compression). Oil then passes the rings and is burnt (consumed) in combustion.... Which causes the dpf to fill too quickly... Which is the other warning sign).
