Sezz
- Messages
- 6
Thanks to everyone who commented on this. I gave fitting mine a go today and it was successful thanks to all the comments and help.
I just ran a hot air gun, or hairdryer, slowly around the velcro to activate the adhesive, note activate. Had lunch, then fitted remainder of top.So i’m sat on a campsite in St Agnes thinking about fitting the isotop and have just read the instructions noting that it needs to be 18deg C and the Velcro Yale has to be left for 48 hours - really?? Do I really need to do that. Realistically that would mean waiting till the summer! Any thoughts?
There are 3 tabs on the beach version, centre and two sides. They line up with the isotop which has small sections of velcro ilke material at the top, not a continuous strip. If you move the tabs it wont hang right or be taught. Its worthwhile lining them up with the actual fabric to get the distances right.On a Beach the front 2 tabs that need screwing to the roof are supposed to be 4cm inset from the side according to the picture. I want to put them closer to the side, around 2 cm in, not 4. Anyone done this? Obviously don't want to damage the roof. Cheers.
I found that the worst bit! Once you get it hooked over the headliner corner it was a matter of a gentle wiggle to persuade it along.Front tabs were fine to fit, anyone got some suggestions as to how you get the rear top bits under the roof at the corners????
We had the same issue, getting it around the back top corners is nearly impossible! It is up and sort of round but not very secure or neat currently.Front tabs were fine to fit, anyone got some suggestions as to how you get the rear top bits under the roof at the corners????
Credit cards work as well (also handy for spreading glue) .I used 2 laminated business cards, inserted 1, then had another with the tab behind it and inserted up into the roof. Then just held the tab in place and removed one card at a time. I am told English £10 note (plastic) is good for it too.
Try the tape measure and a steady pull down, it gives enough space to slip it under....We had the same issue, getting it around the back top corners is nearly impossible! It is up and sort of round but not very secure or neat currently.
Very late to this but we’ve literally just installed our ISO-TOP.Front tabs were fine to fit, anyone got some suggestions as to how you get the rear top bits under the roof at the corners????
Brandrup list the isotop Mk V as suitable for T5 / T6 and T6.1 if that helps.Reviving an old thread, anyone know if the position of the isotop fixings have changed over the years? would an isotop that fitted a T5.1 fit a T6.1 albeit it would only have the normal arched window in the isotop.
Thinking about it the only fixings that could possibly move are the side roof folding struts with the pockets in them for the bit of plastic insert from the isotop & the loops for the safety net.
Given that the shop that cant be mentioned, Camper********* sells the isotop V for T5,T6 and T6.1 I assume nothing has moved. Can anyone confirm?
