Mrs J.H
- Messages
- 23
£7000 for a fuel pump? What else are they replacing? Is there valve damage or something? This sort of thing makes me reluctant to own this van out if warranty.My cali is 8 years old but has only done 50,000 miles. it died on my hubby last week, got towed by a very helpful AA recovery guy to our local garage they are vw approved but not main dealer. AA guy & garage both said fuel pump has disintegrated. AA guy said shouldn't happen at only 50,000. Repair bill by local garage £4,400 to include new cam belt and genuine vw parts or £3100 for Bosh parts. Breeze main dealer quote £7000 cam belt not included! We would normally insist on genuine parts but now unsure due to hefty costs. Have logged a call to VW service centre to see if they will pay any goodwill contribution towards it, as its only done 50,000. Having to wait til Monday for call back, but we may have to pay for it to be transported to Breeze for further investigation. Has anyone had this problem? what would you do pay the local garage or hold out for main dealer to maybe get any goodwill payment & warranties that main dealer should issue??????
Unfortunately Direct Injection Diesel fuel systems are a little more involved. They run at very, very high pressures and if the pump fails then the injectors etc: have to be checked and possibly replaced. The High Pressure pump can generate upto 2000 Bar pressure.Wow, for a fuel pump!...Am I missing something? I'd have expected about £150 + fitting... Why the cam belt change?
Judging by posts on other Forums “ Bad Luck “ I’m afraid, but prolonged periods of inactivity may not be helpful.I had assumed the pump at the tank end, not the one mounted on the block, which I'm guessing is cam belt driven...
Searching online, the pump cost is at least over £1k from aftermarket suppliers.
Does this mean that the pump is also a replacement item on a time / mileage criteria? or just a bit of bad luck...
Price includes: HP & LP Fuel pumps, All Injectors, tank out & full system flush. Cambelt for good measure. Labour is approx 25 hours!
Told common causes are: Miss fuelling or running system dry. Although we haven't done either of these but purchased van at 2 years old!!
Will keep you updated
I wouldn't be too hasty to make a decision.Will keep you updated
No, I think it is something like this - https://www.pfjones.co.uk/volkswage...rds-new-delphi-diesel-fuel-pump-28472762.htmlDoes she mean "water pump"
I also wonder if the repair bill VW charge for transporter vans is the same as they charge for Californias.Good morning,
I am sorry to hear of the problems and the cost to fix it.
Now and then it comes up that some repairs of the California are catastrophical high - more than a normal household can (easily) afford. Obviously, this is very annoying. I expected that the Volkswagen Transporter is not only a very reliable machine, but that the cost of repairs (that includes service and wear and tear) is affordable. Howelse could a small one person craftsmen survive? If an electrician or plumber is confronted with this kind of repair bill, how can he manage? First, I bet the van is gone for a week or longer (because it is a repair out of warranty a replacment vehicle is charged) and second out of the blue paying EUR 8K is unaccaptable.
Are these only the "rare" cases that come to light because they are so bad, or are there more? If it is more, is the Volkswagen Transporter the best base vehicle for a camper? I wonder if the situation with Fiat, Renault or Mercedes is differently?
Regards,
Eberhard
See my post above from T6 forum. Same costs. Not a common problem but it happens. If a VW dealership does the work then you get a 2 yr warranty on the parts and 1 yr on the work. Not so if using an independant or non-VW parts.I also wonder if the repair bill VW charge for transporter vans is the same as they charge for Californias.
I would also be questioning if all that work is really essential. It may what is recommended, but the injectors and LP pump may not actually be damaged. Is there any way of replacing the HP pump, flushing the system and trying it without risking further damage?
My neighbour with a Fiat based motorhome would say it is exactly the same if not more so and a much smaller independent network.Good morning,
Regards,
Eberhard
