Borris
Thanks Hirsty,My Nextbase camera had a piggyback fuseholder on the end of it's power lead & somewhere on this forum I found guidance as to the appropriate fuse to pull out of the nearside footwell & pop back into it.
My power lead then runs under dashboard to the doorframe & up the A-pillar, but I'll admit I'd not fancy running one to the back. At the time I think Mike CFO was doing similar & succeeded.
I've not looked at the unit yet. It's still in the sealed box just in case I decide to take it back.
The front cam doesn't sound too difficult to do. The A post piller trim is easy enough to remove and the wire above that just tucks behind the roof lining. I imagine that below the A post it's merely a case of feeding the wire with the piggy back fuse connector through the back of the dash and then plugging it into the right fuse position.
However, like you I think routing the wire for the rear cam is more of an issue. Firstly, should I go low or go high? I don't fancy trying to route the cable behind the upper trim panels in a Beach. They all look too well attached and I don't want to break anything. So I think it would have to be routed at floor level down the N/S. I know the cable can be tucked under the bottom of the rear N/S trim. Amarillo posted pictures of his solar panel cable taking that route so that shouldn't be a problem. Taking the cable up the inside of the rear pillar and then to the rear camera shouldn't be a problem either. The only real question is what route to take around the front N/S passenger door. Going over the top and down inside the B pillar is probably the best route as the alternative would be under the floor carpet which I'm not keen on.
Writing this has almost given me enough confidence to have a go myself. However I think I'll do as you did first and try and find those threads on the forum.
Thanks again,
Paul
