DavidH
My fridge seems to not be working properly - it did work for a day or so then the yellow light on the control panel turns off when driving....I have tried turning up the setting on the fridge so it is colder and same things happens almost immediately.....I have run diagnostics and no fault showing
I took it into Liverpool - they said they could not detect a fault and suggested that the light might go out on the control panel when it reached the preset temperature which doesn't make sense as it does the same the when I set the fidget to colder and when the light goes out the fridge is saying it is turned off (which makes sense) so will not maintain the temperature - all is we'll with the leisure battery etc - VW Liverpool have now agreed to replace the fridge
I just wondered if anyone else had the same issue?
I have looked through various fridge threads and can't find anything although I seem to remember others having a similar issue
thanks you for help
thanks you for help
