LED lights
lakelander
lakelander
T5 SE 180
Hi
Can‘t find a thread in relation to upgrading my current LED (2) interior lights.
Mine are hardwired to a circuit board - see pics.
Replacement fittings are £50+ a pop and wanting to upgrade all.
Any advice welcome.
How do you mean to upgrade the factory LED lights?
This might help.
This might help.
If we look at his data, it says T5 SE 180 (should mean: T5.1, with the factory LED lights).
I have a 2014 (built 10/13) T5.1, are the interior lights LED?
I have a 2014 180 4motion and yes all the interior cabin lights - just quite dim and would like to replace the bulbs, but apparently it’s not that simple.
have tried Aten and UltraLeds but they are unable to help.
They are led at the moment but only 2!
Yes they are, but as you can see by the photo they are only 2 and the fitting isn’t just a couple of pins they are soldered to a circuit board!
Ae you sure the lights are getting the correct voltage? I have the same vehicle and rarely have more than 2 + the central kitchen light on as they are so bright.
Same here.
The funny thing is, on the first T5, there were bulbs.
On the T5.1 they changed the bulbs into LED's but not as LED bulbs, but the whole light is different.
So you would need some "old" T5 lights and put in some brighter LED bulbs, because, if you would put in higher wattage bulbs, the housing of the lights would melt because of the heat.
Exactly what I did
Hi
Any advice welcome.
I have the exact same problem, where did you find replacement fittings albeit they are £50+. They really are dim in comparison with modern lights
I was watching another thread on upgrading to LED interior lights, bought the replacements, went to fit them this morning only to find they were already factory fitted LEDs
Wished I had seen this thread sooner, anyone need some bulbs?
Stu@rt
Stu@rt
bobbybasic
Devaprem
Devaprem
Devaprem
